Raspberry Pi Forum To build a useable Raspberry Pi Laptop
  • Subscribers 705 subscribers
  • Views 676 views
  • raspberry-pi-bplus
  • portable_battery
  • laptop
kokoroyoma
kokoroyoma over 11 years ago
While browsing around the internet I noticed an article about Pi-Top and thought to myself...It can't be all that hard to find components to make a portable Raspberry Pi Laptop. So, I set out to design my own. After about 20 minutes I had everything I needed. Chalk-Elec sells a 15.6" capacitive touchscreen with a driver board that will power the LCD, backlight and RasPi all at the same time, the only flaw is that it has to be plugged into a wall adapter. The wallwart in question is 5V/3A. I was wondering is how I can supply the laptop with the appropriate power. I have a 5V/2.1A 50.000mAh backup battery that works well if I'm just powering the Pi (and a 3.2" touchscreen I hate), but I'm pretty sure if will not be able to power the much bigger screen, Raspi, and the other options I plan on adding (Keyboard, Wifi, etc.). Also, I'd have to convert a USB cable to match the 5V power supply (OD=5.5mm, ID=2.1mm, central pin is +). If there is a better way of powering this (especially for someone who is at best a hobbiest in the electrical field) I would sure appreaciate any input. Any assistance with this would be GREATLY appreciated!
  • johnbeetem
    0 johnbeetem over 11 years ago
    Many Razzers have used a Motorola Atrix (or other) Lapdock to make a RasPi Laptop:
    http://www.element14.com/community/community/raspberry-pi/blog/2012/09/08/raspberry-pi-laptop
    http://elinux.org/RPi_Screens#Motorola_Atrix_Lapdock
    The Atrix Lapdock is the easiest, but they're getting hard to find and aren't as cheap as they used to be.  Connecting a Lapdock 100 or 500 has problems, so check the linked discussions.
  • kokoroyoma
    0 kokoroyoma over 11 years ago in reply to johnbeetem
    I've already got everything I need planned out for the making of the laptop (except the 3D printed case I'm currently designing). My main problem is just the power. The RasPi, Battery, LCD and other components (Wifi dongle, 4port USB hub, etc.) are all going to be internal components (Some with external holes for access). I know there was to be a way to wire it all up (preferably with a push-through charging system), I've just yet to find out how to do it.
  • clem57
    0 clem57 over 11 years ago in reply to kokoroyoma
    Did you solve?
