Raspberry Pi Forum How to compile kernel on Raspberry 2, can any one helps? for Rasbian y Arclinux
  • Subscribers 684 subscribers
  • Views 615 views
  • frontpage
  • rasbian
  • kenel
  • raspberry_pi_space
  • raspberrypi
alejandroc
alejandroc over 11 years ago
Hi all, does any one help to know how to compile kernel or where to look?
  • clem57
    0 clem57 over 11 years ago
    alejandroc
      Here is a good link for building your own kernel. You can do it onthe Pi itself, or on another machine as a cross compile. If you use another machine, pick a ,inux based because it will be easier to setup.
    Raspberry Pi Kernel Compilation - eLinux.org
    Clem
  • alejandroc
    0 alejandroc over 11 years ago in reply to clem57
    Thanks, is Kernel building process same in Raspberry B+ and Raspberry 2?
    Alejandro
  • clem57
    0 clem57 over 11 years ago in reply to alejandroc
    yes except RPi b+ is ARMV6 and RPi 2 is newer ARMV7...
  • alejandroc
    Thanks Clem, one final question, does anyone knows where I can get a document like this http://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripherals.pdf but for Broadcom 2836?
    Thanks for your help.
    Alejandro
  • clem57
    Oooh! That appears to not be around at the moment. But according to one discussion, the pinouts are the same except for address registers in memory. See http://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98400&p=685323 discussing a program to find the address from the device tree that was loaded at boot time. Also some interesting code for those who twiddle bits and bytes see: Source code for ARM side libraries for interfacing to Raspberry Pi GPU
    Cheers,
    Clem
