Raspberry Pi Forum Charging NiMH Battery while in Use
  • Subscribers 696 subscribers
  • Views 1631 views
  • raspberry-pi
  • gaming
  • 'retro_gaming_console'
I have been trying to figure out if I could use my NiMH battery while it is in use for my current project.  If it is possible, how would I go about doing this?
I am currently making a handheld retrogaming system using Raspberry Pi, a rear view camera monitor, and a NiMH battery.
  • dtsartsanis
    0 dtsartsanis over 11 years ago
    Can u be more specific because i try to understand but i cant.
    If your battery is a Li-ION or LiPoly you can use something like this http://www.adafruit.com/products/1944 if your battery is a common NiMH use a charger.
  • jlcarender
    0 jlcarender over 11 years ago
    You would need to buy or make a charging circuit for you particular type battery check out Ben's
    raspberry-pi mame portable
    0 Former Member over 11 years ago in reply to jlcarender
    I already have a way to charge it, and it just goes directly to the battery wires.  Would the circuit still function properly if the charger was in the circuit.
  • clem57
    0 clem57 over 11 years ago in reply to Former Member
    It could depending on the circuit being used. Phones charge while in use just not as fast. But some circuits will cut off while charging going back to my first statement.
    Clem
    0 michaelkellett over 11 years ago in reply to Former Member
    I just wrote a detailed reply to you and E14 dumped it with a bizarre error message - no time to do it over again so here's a summary.
    You can only trickle charge using the connections you describe. If you want to fast charge you will need to design a more complex circuit where the load is driven directly by the externl supply whn it's available and the battery is charged by a separate charging circuit and have some kind of switch to connect the load directly to the battery when there is no external power.
    The first link is  a quite detailed description of NiMH batteries and  the second a  general FAQ.
    data.energizer.com/PDFs/nickelmetalhydride_appman.pdf
    http://www.gpbatteries.com/INT/index.php?option=com_k2&view=item&layout=item&id=236&Itemid=478
    0 Former Member over 11 years ago in reply to michaelkellett
    Ok, then I guess I will just make the battery removable for charging, this looks like too steep a learning curve for me at the moment.  (I don't really know much about circuits or how electricity works)
