Raspberry Pi Forum Raspberry pi 2 and gertduino
  • Subscribers 706 subscribers
  • Views 1223 views
  • raspeberry_pi_accessories
framboosej
framboosej over 11 years ago
I have a gertduino wich works fine on my Raspberry Pi B+. Than i did buy a Raspberry Pi 2. My Gertduino don't work on the RPi 2. I checked everything and Even installed a new version of Raspbian on my RPi B+ and installed the gertduino software again on both the RPi 2 and RPi B+. I am sure both sytems have the same software now and the same settings.
I can program the gertduino on the RPi B+ but NOT on the RPi 2. I use the same avrdude from gordon on both RPi's. but ./avrsetup doesn't work on my RPi 2. I don't know what to do, please help me.
  • clem57
    0 clem57 over 11 years ago
    Try the following because this may be software related...
    sudo apt-get update
    sudo apt-get install python-dev
    sudo apt-get install python-rpi.gpio
  • clem57
    The specified item was not found. is this where you got the software from?
    Clem
    Well, I've also a Gertduino with RPi 2.  Working well after struggling for a few days.  What I discovered, the GPIO behavior in Raspbian had been changed.  The reset pin for Gertduino (GPIO 8 on RPi) is now in default Input mode, so the level sensed by the Gertduino will be LOW (reset active, not running).  With the script reset_off in the Gertduino manual, the reset pin will revert back to Input mode after the last statement (echo 8 > /sys/class/gpio/unexport).  So, the Gertduino uC will not run.  I solution is to run the reset_off script manually, and leave the last statement.  I've no problem to program the uCs on Gertduino, either by avrdude from Gordon or by using Arduino IDE (with patching).
    My 2 cents.
    Stephen Wong @ Hong Kong
  • robin38
    0 robin38 over 8 years ago
    hi everybody
    no way to have gertduino ok with raspberry.
    does anyone really had it work one day ?!?
    raspberry pi3
    gertduino rev5
    raspbian jessie
    i'm lossing my faith ....
    this is the issue i get every time
    avrdude: AVR device not responding
    avrdude: initialization failed, rc=-1
             Double check connections and try again, or use -F to override
             this check.
    i made all those stuf :
    Gertboard | Arduino IDE Installation (ISP) | Gordons Projects
    https://www.raspberrypi-spy.co.uk/2013/12/gertduino-getting-started-tutorial-hello-world/
    is there someone to help. thanks a lot.
  • rasparp
    0 rasparp over 5 years ago in reply to robin38
    Hello. Are you still using the Gertduino board.
    Agreed it is a difficult board.
    I have some tips for you. Are you still using it and interested.
    Dian from the Netherlands
