Raspberry Pi Forum Raspberry PI - QNX
  • Replies 28 replies
  • Answers 7 answers
  • Subscribers 713 subscribers
  • Views 11149 views
  • qnx
Raspberry PI - QNX
varghese_a
varghese_a over 11 years ago
Has any one tried porting QNX on Raspberry pi ?
I am planning to take it up atleast the Graphics (HDMI) & Network part.
Varghese
  • varghese_a
    0 varghese_a over 9 years ago
    I have made it work after 2 years ...
    QNX BSP Support is added to Raspberry (bcm2835)... I made it open source ...
    Hack: Raspberry Pi(BCM2835) QNX 6.5 Sp1 Source code
    • Vote Up +6 Vote Down
  • gdstew
    0 gdstew over 9 years ago in reply to varghese_a
    Congratulations ! You are one persistent person. I checked out your link and like I said previously I would really like to experiment with
    this but I just can't afford or get around the license requirement. I see that that has (not surprisingly) prevented you from publishing an
    image also. Oh well.
  • varghese_a
    0 varghese_a over 9 years ago in reply to gdstew
    yes there are restriction on distributing the final qnx image ( it used to be 150$ per system run time license  image , now they might have reduced it ) ,  but no restriction on giving the BSP  source code ..  Its free and apache license .. I have updated the source code link.. (Need QNX 6.5 IDE to compile )
  • anantpai
    0 anantpai over 9 years ago in reply to varghese_a
    I am working on porting QNX on raspberry pi board. Browsing through internet found this page. I tried downloading the BSP source from this link.
    https://www.element14.com/community/external-link.jspa?url=http%3A%2F%2Fihaack.blogspot.in%2F2016%2F12%2Fraspberry-pibcm…
    The link appears broken. Can somebody provide the correct link. This would help in speeding up the board bringup activity.
    Regards
    Anant
    0 mcb1 over 9 years ago in reply to anantpai
    It's a link external to the website
    I suggest you make contact with the owner of that site.
    Electronics / Embedded / Firmware /Software /Hacking
    0 mcb1 over 9 years ago in reply to mcb1
    Type QNX into the search at the top left and you'll find several references
  • anantpai
    0 anantpai over 9 years ago in reply to mcb1
    Thanks for your response will check with owner of the site.
  • varghese_a
    0 varghese_a over 9 years ago in reply to anantpai
    the link is down ...
    I have pushed it to the github ..
    https://github.com/varghes/Raspberry-QNX
    Source code is free/opensource ,  but any commercial distribution of final qnx image requires run time license from QNX..
    I have kept the final image for testing / academic use.. as this board is normally used for hobbyist..
  • vlinus
    0 vlinus over 9 years ago in reply to varghese_a
    Could you help to introduce how to create an academic license?
    Is the progress very complicated?
  • volly
    0 volly over 9 years ago in reply to anantpai
    anantpai/
    here is the link:
