Raspberry Pi Forum Raspberry PI - QNX
  • Replies 28 replies
  • Answers 7 answers
  • Subscribers 713 subscribers
  • Views 11159 views
  • qnx
Raspberry PI - QNX
varghese_a
varghese_a over 11 years ago
Has any one tried porting QNX on Raspberry pi ?
I am planning to take it up atleast the Graphics (HDMI) & Network part.
Varghese
  • dobroviciandrei
    0 dobroviciandrei over 9 years ago
    Will it work also on Raspberry Pi 3 Model B?
    if not, how much time would it take to port it?
    Thank you.
    0 balearicdynamics over 9 years ago in reply to dobroviciandrei
    AFAIK the PI3 architecture I think there is not a structural difference creating some impeachment that we will expect it can't work. But the best choice is to try.
    Enrico
  • varghese_a
    0 varghese_a over 9 years ago
    Memory map is same , so Single core might run ... I have not tested it on rpi 2/3 ...
    To run other cores , we need to turn on SMP , which is not yet implemented ..
  • varghese_a
    Well, at present I am in the process of adding mmc & USB support to BCM2835 ,  if any one wants Raspberry 2 & 3 (BCM2836/BCM2837)  urgently, then they should donate me that  board image image  image .  at present we have fully working beaglebone black (including HDMI video /USB )  + QT apps
    https://github.com/varghes/BeagleboneBlack-QNX-QT
  • dobroviciandrei
    0 dobroviciandrei over 9 years ago in reply to varghese_a
    I am interested in doing work for BBB or Raspberry pi 3 for porting QNX to these targets.
    Do you need any help?
    Thank you.
  • varghese_a
    0 varghese_a over 9 years ago in reply to dobroviciandrei
    all features of BBB is working fine .. on Raspberry 3 ,hopefully I will get a board by Oct end , Mean while you can copy the content https://github.com/varghes/Raspberry-QNX/tree/master/working_image
    to sd card & boot that with raspberry 3 & let me know what error it displays /stucks. I am working on MMC & USB part , may be you can help me on that
  • jareddsimon
    0 jareddsimon over 9 years ago
    There is a project I want to work on with QNX on the Raspberry Pi 3. So, I would very much like to see this happen!!
  • revatimali1111
    0 revatimali1111 over 8 years ago in reply to varghese_a
    Have you worked on topic QNX6.5 for raspberry pi 3(BCM 2837)? I want to install it on BCM2837...will you please help me out?
