Raspberry Pi Forum 'Serial' object has no attribute 'fd'
  • Subscribers 674 subscribers
  • Views 1148 views
  • hdc1000evm
  • raspberrypi
  • serial
wymand
wymand over 10 years ago
I am trying to use python (or python3) to evaluate the TI HDC1000EVM. I can see the device in /dev as /dev/ttyACM0 it also appears in /dev/serial/by-id/usb-Texas_Instruments_MSP430-USB_Example_E89A816F1C000500-if00 -> ../../ttyACM0
However when I try to open the device using python serial I get an error that it can't open the serial port 'Serial' object has no attribute 'fd' Anyone have any ideas why??? I tried disabling the default serial port in initdev but no luck, same error.
Thanks for ANY ideas :?:
Doug Wyman
Keep on learning
Keep on evolving
  • wymand
    0 wymand over 10 years ago
    HAH!!!!  I found the cause.
    Being an old timer serial programmer it has been my good practice to set RTS and DTR.
    NO!!!!!  I did a line by line check and the setting of either caused the no attribute fd error.
    Plugging along, I am getting returns from the module in fact more than expected.
    Thank you
