Raspberry Pi Forum RCA Port not working on raspberry pi 2
  • Replies 7 replies
  • Subscribers 708 subscribers
  • Views 2022 views
sahas
sahas over 11 years ago
Got a black and white screen and a unreadable text on my screen. Pls help
  • clem57
    0 clem57 over 11 years ago
    element14Dave please move to Raspberry Pi 2 area thanks you sir.
  • clem57
    2 down vote
    Yes, you can direct connect! The first set of inputs you mention, the "Yellow-White-Red" is called composite or RCA video. The Raspberry Pi supports this, it's the matching little Yellow RCA connector on the Pi, next to the headphone jack (see diagram). Connect this with an RCA cable to the matching Yellow connector on the TV and you're set. The White and Red jacks are left and right channel audio respectively. You need a 1/8" stereo to RCA, or phono when it's audio, cable if you want audio through the TV as well. On the Pi you'll also have to enable audio out over the 1/8" jack by editing the config.txt file, by setting hdmi_drive=1. When Linux boots you'll also need to run amixer cset numid=3 1.
    That's one option. Without knowing more about your TV, what I'm about to write about is a bit speculative. Generally the Y/Cb/Cr is a higher quality video input called component video. It's analogous to VGA like computer monitors originally used. It's what the original fat Xbox 360s used for connecting, for example. The Raspberry Pi doesn't support this, but the Pi does do HDMI, and there are lots of conversion boxes to go from HDMI to Component video. This is a bit sketchier though, so you're probably best off using the composite video until you get used to things and want to experiment."display - How do I connect Raspberry Pi to my TV? - Raspberry Pi Stack Exchangedisplay -"
  • clem57
    Traditionally composite video uses the yellow coloured sockets whereas audio uses the Red (Right channel) and White (Left channel). Cables are available with both RCA plugs or RCA sockets on the end. Make sure you buy a cable with the appropriate connectors for your video and audio accesoriesModel-B-Plus-Audio-Video-Jack-Diagram.png
  • Problemchild
    0 Problemchild over 11 years ago
    Yeah the Video Outputs on a 4 ring 3.5"" jack is quite common and Farnell's sister company CPC even stocks them.
    If you are getting a picture your cable is probably OK.  What you will need to do is check that the PI is outputting the correct TV standard Pal or NTSC depending on your country.
    Additionally check you are using a 4 ring Jack connector because otherwise it will short the video to  one or both of the audio out puts depending on if it's a stereo or mono cable.
  • mconners
    0 mconners over 11 years ago in reply to clem57
    clem57 What is that 2 down vote thing? Is this a new feature?
    Mike
  • mconners
    0 mconners over 11 years ago in reply to mconners
    clem57,  nvm, I see, looks like you copied that from elsewhere. I would normally attribute something I copied from another site. That's just me.
    Mike
    0 mcb1 over 11 years ago in reply to clem57
    I seem to recall a similar question way way back.
    We tried identifying cables on the site and they lacked details.
    If my memory serves correct (not guaranteed lately image)  element14jamie was looking at it for us...
    I might have missed the answer.
