Raspberry Pi Forum MP3 Playback on PI Pico
  • Replies 12 replies
  • Subscribers 703 subscribers
  • Views 11307 views
  • pico
  • mp3
scottiebabe
scottiebabe over 5 years ago
Soft 404
  • neuromodulator
    neuromodulator over 5 years ago
    Cool project, I've played a bit with that using FPGAs. I've never tried with MCUs, but FPGAs give you very tight timing control. I wonder if you can broadcast the audio signal.
    DAB over 5 years ago
    Nice project.
    The sinewave file scared my dog.
  • bobross427
    bobross427 over 4 years ago
    Hey I'm new to this and can follow the wiring diagrams just fine, copy and paste just fine.
    I have tried a couple of the code examples for mp3 playback that seem to work good, with the intent to make a noise or rain machine, but cant get the files to play in a loop.
    ------- original example -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
    CircuitPython multiple MP3 playback example for Raspberry Pi Pico.
    Plays two MP3 files consecutively, once time each.
    import board
    import audiomp3
    import audiopwmio
    audio = audiopwmio.PWMAudioOut(board.GP0)
    mp3files = ["rain1.mp3", "rain2.mp3"]
    mp3 = open(mp3files[0], "rb")
    decoder = audiomp3.MP3Decoder(mp3)
    for filename in mp3files:
        decoder.file = open(filename, "rb")
        audio.play(decoder)
        print("Playing:", filename)
        while audio.playing:
            pass
    Thanks if you have a working idea.
  • scottiebabe
    scottiebabe over 4 years ago in reply to bobross427
  • robogary
    robogary over 4 years ago
    Saweet. Did you need to load the MP3 files also to the Pico ?
    Will you add a LM386 to drive a 8 ohm - ish speaker ?
  • scottiebabe
    scottiebabe over 4 years ago in reply to robogary
  • bobross427
    bobross427 over 4 years ago in reply to scottiebabe
    Thanks that worked after about half hour, when I realized the T in true needed to be True, per your example.
    Thanks again.
  • robogary
    robogary over 4 years ago in reply to scottiebabe
    Thanks for the good explanation. I learned alot and have alot to learn.
  • robogary
    Alot of times I'll just get 5W or 15W class D amp boards  https://www.amazon.com/Ximimark-1-8-12V-TDA2822M-Amplifier-Channel/dp/B07KC1CZWY/ref=sr_1_4?dchild=1&keywords=12v+amplif…
    I cant build them nearly as cheap as buying them.
    I have built LM386 boards and 5V relay cards, once, then found just the parts cost 2-3X as much as buying a prebuilt surface mount one.
  • jc2048
    jc2048 over 4 years ago in reply to scottiebabe
    Won't you need to close the files when they're no longer being used, or does Python handle that kind of thing for you?
