Raspberry Pi Forum Sensor/IoT device to send an alert message - Squirrel Traps
  • Replies 17 replies
  • Subscribers 704 subscribers
  • Views 4523 views
DigitalHillbilly
DigitalHillbilly over 4 years ago
Greetings, I am new to the forum.  I want to make a device that will send a message/email/other home automation protocol message when an event happens (trap trips). I have looked at several microcontrollers ESP32, firebeetle, etc..., Pi and Arduino devices, but looks like the Pi Zero might be my best (easiest) solution. I wanted to keep it simple, and very cheap (under $20 if possible)... I need the device to be battery powered, and portable. (I don't like the idea on connecting a wall outlet to a metal cage.)  It doesn’t need to be on all of the time, when the event happens two contact plates touch, a circuit is closed (or a button pushed) the device powers up and send the message. At this point it can be programmed to shut down, or just let the power drop off until it fails.. I don’t really care here... It’s a pain to get into these attic areas every day to check, as fiberglass insulation gets everywhere, I would rather know when something is trapped, so I can go take the squirrel to a park and let it go. I had one die and decompose in a trap a long time ago, and it was messy.. Don’t want to do that again. My purpose is not to kill them,, just get them out of my attic, they are damaging my home.
My experience with power bricks is that there is usually a button that has to be pushed to activate or wake them up, they don't usually just serve power when the connected device powers up, at least the ones I have. I can't seem to find any 5V batteries with a micro USB cable ready for the Pi Zero. Weird, I would have thought someone somewhere would have made one by now.  I don’t need more than maybe 5-10 minutes of on time, the pi to power up, connect to my home Wi-Fi, send the message, then shutdown, all of that is easy enough to set up. I had thought there would be some IoT sensor or device out there to handle this type of thing, but I haven’t found anything yet... So it’s back to a Pi solution...
I work in Critical Infrastructure and Cyber Security and am expanding my skillset a bit with some of these types of projects, and IoT and IIoT sensors and like devices are on the rise... It seems that a device similar to this could be used for a whole slew of functions and situations, weird no one has a solution yet... I'm starting small and simple, with plans to go on to bigger and better things.. Any help, recommendations, or suggestions are welcome Slight smile
  • DigitalHillbilly
    0 DigitalHillbilly over 4 years ago in reply to dougw
    Thanks, that is truely a simple solution, and I might take that route, but I do want to play a little first ;)
  • DigitalHillbilly
    0 DigitalHillbilly over 4 years ago in reply to ralphjy
    Thanks, I have been researching and learning a lot the last couple of weeks. I did finally find and get a PI zero that someone had in stock, but the cost was high... and portable power is still a big problem. However, I am now looking more heavily at several of the ESP32 dev kits, and ESP-Now. These boards are extremely cheap, and versatile, and have rechargeable batteries already available, and could be repurposed later on for other projects I am thinking on. It seems that SMTP is a bit difficult on these microcontrollers, and the ESP-Now communication solution would simplify the whole project.
  • DigitalHillbilly
    0 DigitalHillbilly over 4 years ago in reply to shabaz
    Agreed, I am focusing on the ESP32 dev boards now, and ESP-Now for communications.
  • DigitalHillbilly
    Agreed. I havent seen any boards for $3, usually around $10 but still really cheap. and they have rechargable batt packs already available, and can be repurposed later on.
  • DigitalHillbilly
    0 DigitalHillbilly over 4 years ago in reply to beacon_dave
    I thought about that or maybe a motion senser, or even an IR camera set up. But for now, just knowing something disturbed the trap is enough. The project is giving me a lot of new ideas for things I want to do for my home, so its a step on a new path of home projects ;)
  • DigitalHillbilly
    0 DigitalHillbilly over 4 years ago in reply to scottiebabe
    Thanks, I was thinking about just attaching a push button under the trip plate, or maybe even just a wire to complete the path.. But I’ll keep that in mind, however being a little paranoid on the cyber security side, I don't like connecting outside systems to my home networks, or even my side/sub nets I have set up for similar devices and or cameras. Which most of these IFTTT solutions require.
  • DigitalHillbilly
    0 DigitalHillbilly over 4 years ago in reply to BigG
    Thanks for the suggestions, I’ll look closely into each one of them. Wi-Fi signal was one of the first things I thought of, and the distance from the closest WAP, and the number of walls (amount of wood and sheetrock) the signals would need to navigate. The BLE was one of the methods I have considered, and might still end up using, but right now I am playing with the ESP-Now communication method, it seems to have more than adequate range to cover my home. My secondary purpose for this project was to educate myself on what was possible now, what technologies already existed, and or what was new that I didn’t know about. So thanks again for helping me on both points Blush
