Raspberry Pi Forum Sensor/IoT device to send an alert message - Squirrel Traps
  • Replies 17 replies
  • Subscribers 702 subscribers
  • Views 4591 views
DigitalHillbilly
DigitalHillbilly over 4 years ago
Greetings, I am new to the forum.  I want to make a device that will send a message/email/other home automation protocol message when an event happens (trap trips). I have looked at several microcontrollers ESP32, firebeetle, etc..., Pi and Arduino devices, but looks like the Pi Zero might be my best (easiest) solution. I wanted to keep it simple, and very cheap (under $20 if possible)... I need the device to be battery powered, and portable. (I don't like the idea on connecting a wall outlet to a metal cage.)  It doesn’t need to be on all of the time, when the event happens two contact plates touch, a circuit is closed (or a button pushed) the device powers up and send the message. At this point it can be programmed to shut down, or just let the power drop off until it fails.. I don’t really care here... It’s a pain to get into these attic areas every day to check, as fiberglass insulation gets everywhere, I would rather know when something is trapped, so I can go take the squirrel to a park and let it go. I had one die and decompose in a trap a long time ago, and it was messy.. Don’t want to do that again. My purpose is not to kill them,, just get them out of my attic, they are damaging my home.
My experience with power bricks is that there is usually a button that has to be pushed to activate or wake them up, they don't usually just serve power when the connected device powers up, at least the ones I have. I can't seem to find any 5V batteries with a micro USB cable ready for the Pi Zero. Weird, I would have thought someone somewhere would have made one by now.  I don’t need more than maybe 5-10 minutes of on time, the pi to power up, connect to my home Wi-Fi, send the message, then shutdown, all of that is easy enough to set up. I had thought there would be some IoT sensor or device out there to handle this type of thing, but I haven’t found anything yet... So it’s back to a Pi solution...
I work in Critical Infrastructure and Cyber Security and am expanding my skillset a bit with some of these types of projects, and IoT and IIoT sensors and like devices are on the rise... It seems that a device similar to this could be used for a whole slew of functions and situations, weird no one has a solution yet... I'm starting small and simple, with plans to go on to bigger and better things.. Any help, recommendations, or suggestions are welcome Slight smile
  • beacon_dave
    0 beacon_dave over 4 years ago
    MKR WiFi may be another option worth looking at.
    https://store.arduino.cc/products/arduino-mkr-wifi-1010
    https://store.arduino.cc/products/arduino-mkr1000-wifi
    They have battery charging built-in so don't need the full power brick, just add a battery directly to them.
    • Vote Up +5 Vote Down
  • ralphjy
    0 ralphjy over 4 years ago
    I like M5Stack M5StickC modules for simple WiFi sensors.  Here is a post I wrote about them: m5stickc-modules
    Unfortunately the lower cost modules are hard to find, but you can find the Plus modules for $21 at Digikey K016-P
    They have a small battery, display and a few GPIO and use an ESP32 processor.  If you were going to power up for short intervals occasionally, the built-in battery might work.  I tend to use them with a USB power pack to run continuously.  There is also a PMIC, so you can check battery status.
    They can be programmed via the Arduino IDE, so setup is pretty simple.
    • Vote Up +6 Vote Down
    0 shabaz over 4 years ago
    Both of the options mentioned (MKR WiFi and M5Stack) are better options for this use-case than the Pi Zero. Pi Zero can be useful for Linux appliance scenarios perhaps, but is overkill on the processing side, and is missing significant features which you may need (like battery charging, low power consumption and good sleep options).
    0 dougw over 4 years ago
    A low cost solution is to use an ESP32 (~$3) module and a battery (a couple of AA batteries). The contact closure you mentioned could connect the battery voltage to the ESP32, which would power up and send WiFi messages notifying you of the event.
  • scottiebabe
    0 scottiebabe over 4 years ago
    You can try searching for ifttt compatible wireless door sensors. Which are usually magnetically triggered and I'm sure you could adapt somehow to this application.
  • BigG
    0 BigG over 4 years ago
    I always start by looking at your requirements.
    Then I look at some obvious solutions. You've listed one already.
    Well, I do recall this chap on YouTube who designed his own WiFi board which did all this power management for you so that it could operate off a battery. He called it a TrigBoard.
    I believe you can buy it on Tindie - although it looks to be more than $30. Here's the YouTube video: https://www.youtube.com/watch?v=CD-jmSkM3d4
    Then, instead of the standalone options, another way to go is look at a cloud based platform which incorporates a dev board. This helps with the notification side. An example would be Particle.io and they offer a Photon board for less than $20: https://store.particle.io/products/photon?_pos=3&_sid=883694116&_ss=r
    However, from a requirements perspective, you have to first consider the distance and communication reliability from your WiFi router to the device if you want to use WiFi. Also WiFi is quite power hungry as it provides more bandwidth and speed than you really need for the application. So not sure if this really is the best solution out there. An alternative low power wireless option for you would be a Bluetooth Low Energy (BLE) device, which can connect to your phone or a tablet to act as a bridge etc. There are plenty of devices under $20. For example, the BGM220 Explorer Kit (community.element14.com/.../silicon_labs_ble_exp.
    For Arduino fans there is also a new lost cost BLE board from SeeedStudio for <$10. Although its still at preorder stage: www.seeedstudio.com/Seeed-XIAO-BLE-nRF52840-p-5201.html
    Otherwise you are looking at LoRa or sub GHz wireless devices.
    Hope this helps.
  • beacon_dave
    0 beacon_dave over 4 years ago in reply to dougw
    There is also the ESP32-CAM if 'photographic evidence' of a successful catch was required. Would likely require the addition of a couple of LED's to briefly illuminate the scene in a dark attic space.
    If you want minimal effort, you could just wire your contact closure to a commercial remote control fob that turns on power at an outlet. You just plug in a lamp at the controlled outlet. I use a cheap one to turn on Christmas lights.
  • phoenixcomm
    0 phoenixcomm over 4 years ago in reply to dougw
    /members/dougw the supreme minimalist!!
  • DigitalHillbilly
    0 DigitalHillbilly over 4 years ago
    Thanks everyone :) I stepped away for a few days, sorry for taking so long to respond. I am playing with ESP32 dev kits right now, but I will look into each one of your suggestions. Thanks again Slight smile
