Raspberry Pi Forum How to solder fairy light strings
  • Replies 14 replies
  • Subscribers 704 subscribers
  • Views 7664 views
scottiebabe
scottiebabe over 4 years ago
I have been experimenting with tri-state multiplexing with the Rp2040's PIO statemachine and have found good success.
The PIO code is quite interesting in that its quite different from how I might write it in c-code in a repeating ISR. I may write a blog about it in the future, but here is the code:
# Tri-state multiplexing with done with PIO statemachine
# -scottiebabe 2022
import time
from machine import Pin
import rp2
# Ensure pin pull-ups and pull-downs are disabled
# So pin is Hi-Z when set as input
Pin(0,Pin.IN)
Pin(1,Pin.IN)
Pin(2,Pin.IN)
@rp2.asm_pio(out_shiftdir=rp2.PIO.SHIFT_RIGHT,set_init=[rp2.PIO.OUT_LOW]*3,out_init=[rp2.PIO.OUT_LOW]*3)
def charlie():
    pull(noblock)
    mov(x,osr)
    # Set Pin0 & Pin1 as outputs
    in_(null,2)
    in_(osr,1) # output state of LED0 on Pin0
    out(null,1)
    set(pindirs, 0b011)
    mov(pins, isr) [7]
    in_(null,1)
    in_(osr,1) # output state of LED1 on Pin1
    in_(null,1)
    out(null,1)
    mov(pins, isr) [7]
    # Set Pin0 & Pin2 as outputs
    in_(null,2)
    in_(osr,1) # output state of LED2 on Pin0
    out(null,1)
    set(pindirs, 0b101)
    mov(pins, isr) [7]
    in_(osr,1) # output state of LED3 on Pin2
    in_(null,2)
    out(null,1)
    mov(pins, isr) [7]
    # Set Pin1 & Pin2 as outputs
    in_(null,1)
    in_(osr,1) # output state of LED4 on Pin1
    in_(null,1)
    out(null,1)
    set(pins,0)
    set(pindirs, 0b110)
    mov(pins, isr) [7]
    in_(osr,1) # output state of LED5 on Pin2
    in_(null,2)
    out(null,1)
    mov(pins, isr) [7]
# Create the StateMachine with the charlie program, outputting on Pins 0-2.
sm = rp2.StateMachine(0, charlie, freq=20000, set_base=Pin(0),out_base=Pin(0))
# Put bitmap into pio statemachine
sm.put(0b101)
# Start the StateMachine.
sm.active(1)
i = 0
while True:
    i += 1
    sm.put(i % 64)
    time.sleep(0.1)
I would like to try and make my own fairly light strings with three wires and 6 LEDs, similar to these
What do you think the best way to solder the LEDs to wires would be?
I'm thinking maybe use a piece of perfboard to hold everything in place while soldering
  • fmilburn
    0 fmilburn over 4 years ago in reply to scottiebabe
    Maybe put a tiny piece of Blue Tack down to hold the LED.  My granddaughter and I built the Lego "Andrea's Family House" kit a while back and lit it.  I'm thinking we might try something else.
  • colporteur
    0 colporteur over 4 years ago in reply to dougw
    Are you able to share more details on the LED's? I'm looking for a replacement LED package and find that experience is the best feedback for picking something.
    0 dougw over 4 years ago in reply to colporteur
    They seem to be hard to specify but if you search on Ali Express for
    0807 LED SMD Diode Slow Flashing Fast Flashing
    You will find  lots of them.
    I have no idea who the manufacturer is or what the real part number is.
  • Jameswalter
    0 Jameswalter over 3 years ago
    LED fairy light strings come in two main types. The commonest sort run off low voltage AC, supplied by a small transformer. The transformer is capable of running the string it was supplied with, and not much more. The LEDs are wired in parallel strings of series lamps, and the voltage from the transformer doesn't get supplied to the end of the string. No amount of soldering will permit another string to be tacked on the end successfully.
