Raspberry Pi Forum RP2040 PIO Sideset enable bit is automagically set in uPython
  • Subscribers 701 subscribers
  • Views 1398 views
scottiebabe
scottiebabe over 4 years ago
Thanks to BigG I was made aware of a feature in the RP2040's statemachines where the sideset value can be latched and doesn't need to be defined for every instruction.
Posting here, not to overhelm their amazing project. Taking an I2S pio program as an example:
@rp2.asm_pio(out_shiftdir=0, autopull=True, pull_thresh=32, out_init=[PIO.OUT_LOW],sideset_init=[PIO.OUT_LOW]*2,fifo_join=PIO.JOIN_TX)
def samplepio():
    wrap_target()
    label('entry')
    set( x, 14)             .side(0b11)
    label('bitloop1')
    out( pins, 1 )          .side(0b10)
    jmp(x_dec, 'bitloop1')  .side(0b11)
    out( pins, 1)           .side(0b00)
    set( x, 14)             .side(0b01)
    label('bitloop0')
    jmp( x_dec, 'bitloop0') .side(0b01)
    wrap()
When I print out the assembled machine code for this pio routine using:
addr = 0
for instr in samplepio[0]:
    bcode = '{:016b}'.format(instr)
    print('{:02X}: {:} {:} {:}'.format(addr,bcode[0:3],bcode[3:6],bcode[6:]))
    addr +=1
I get the following:
00: 111 110 0000101110
01: 011 100 0000000001
02: 000 110 0001000001
03: 011 000 0000000001
04: 111 010 0000101110
05: 011 000 0000000001
06: 000 010 0001000101
07: 011 100 0000000001
You can see only 2 bits are used for the sideset values.
If I comment out one sideset directive, then uPython automagically enables the sideset enable bit and the instructions now appear as:
00: 111 111 0000101110
01: 011 110 0000000001
02: 000 111 0001000001
03: 011 100 0000000001
04: 111 101 0000101110
05: 011 100 0000000001
06: 000 101 0001000101
07: 011 000 0000000001
I commented out the last sideset directive and you can see the presence of an enable/latch bit on all previous instructions.
Thanks to BigG, I learned something new!!!
