Raspberry Pi Forum NOAA Weather satellite setup on a Raspberry PI 4 using Raspberry OS either 32 or 64 bit
  • Subscribers 703 subscribers
  • Views 2253 views
TekMaker
TekMaker over 4 years ago
I do the step by step setup for the Raspberry PI OS 32 bit version, but it should equally work for the 64 bit version as I have done it previously. All you need is an SDR, aerial and a Raspberry PI 4 with Raspberry PI OS installed and about an hour to do it.
I show you how to install rtl-sdr drivers, GQRX, GPredict and WxToImg and set up automated recordings.
These instructions will work for any Debian/Ubuntu distro too including 64 bit
Checkout my blog for this and other articles in depth
www.tekmaker.co.uk/.../receiving...
https://youtu.be/23HufpD1cu0
    shabaz over 4 years ago
    (Duplicate post, should be deleted). There appear to be three identical posts (sometimes the system is slow to show the new posts, but that doesn't mean they are lost, they will appear eventually).
  • TekMaker
    TekMaker over 4 years ago in reply to shabaz
    Yeah, I am new here and can;t find how to delete them
    shabaz over 4 years ago in reply to TekMaker
    I see.. I'm not sure either, this may be an issue due to this being a forum discussion rather than a blog (the latter has a delete option as far as I'm aware).
    It may require cstanton to do the deletion or suggest a way.
  • cstanton
    cstanton over 4 years ago in reply to TekMaker
    On a desktop computer, if you have permission to delete them, it's under the 'more' option
    But there's other issues I kinda take with your post.
    1. Your link to your blog doesn't work?
    2. You could've blogged your project on element14, rather than simply advertising a link to your blog - do consider blogging on the Community.
    3. You can go insert->video to insert the youtube video.
    4. The post is more suited to the Raspberry Pi group - so I moved it.
    Also, it could be a blog, that would be more preferable than a discussion perhaps. You can start a blog by clicking on the red highlighted bit:
    (that page is Raspberry Pi Projects).
    Then, there are editor tools:
    And video insertion as cstanton mentions:
    Photos are inserted using the same tool. The photos and videos can be resized by dragging the corner.
    Code snippets can be added (for instance if your code is on GitHub but you wish to show some code directly in the blog for context):
    You can also do inline code or shell commands by highlighting the text and then selecting the inline code format like this:
    Sometimes it's worth bolding it too (highlight the text and type Ctrl-B).
    Also contents insertion at the beginning of the blog post after you have the rest of the content done:
    It then looks like this:
    Insert some tags, and click Post:
