Raspberry Pi Forum TinyML - Voice on Raspberry Pi Pico.
  • Replies 8 replies
  • Subscribers 701 subscribers
  • Views 8315 views
  • voicecommand
  • raspberry pi pico
  • tinyml
Sudeep AJ
Sudeep AJ over 3 years ago
So I recently bought a Raspberry Pi Pico (RP2040) and I also found this amazing website called edge impulse(www.edgeimpulse.com) which lets us train tinyML models without any code and gives us the library optimized to the microcontroller board we choose.
Now I want to make a tinyML project to do operations through my voice. Raspberry Pi doesn't have a microphone so I have to connect a microphone module to its ADC pin. But I am not able to get how to move forward with this. How can I use the C++ that I export through edge impulse and use it in my code? Does anyone has any experience building similar project? If someone could guide me with how to do this suing tensorFlowLite also that would be helpful.
    dougw over 3 years ago
    Here is an example - maybe you can have a look at the source code which is on Git Hub... it seems to use TensorFlow...
    https://www.youtube.com/watch?v=V0KXZGhHUQY&ab_channel=Forbes
  • feiticeir0
    feiticeir0 over 3 years ago
    Hi !
    I've only experience with Python using the Pico and PDM microphone for ML projects.
    Nonetheless, there's some examples that use C++
    https://blog.tensorflow.org/2021/09/TinyML-Audio-for-everyone.html
    https://towardsdatascience.com/audio-deep-learning-made-simple-sound-classification-step-by-step-cebc936bbe5
    Coursera has some courses of embedded Machine Learning - using TinyML and Pico or Arduino Sense
    https://www.coursera.org/learn/introduction-to-embedded-machine-learning/home/week/1
    There are some excellent, excellent books on that topic
    https://www.oreilly.com/library/view/tinyml/9781492052036/
    https://www.packtpub.com/product/tinyml-cookbook/9781801814973?_ga=2.81539028.270938506.1677456360-1555116499.1677456360
    With this, you can create your project.
  • Sudeep AJ
    Sudeep AJ over 3 years ago in reply to feiticeir0
    Can you please tell me more about your Pico and PDM Microphone ML project using Python?
  • feiticeir0
    feiticeir0 over 3 years ago in reply to Sudeep AJ
    Hi !
    You know you can program the Pico with the Arduino IDE using mbed . That way, you can use Edge Impulse with the PICO.
    About that project I'm still working on that... Still haven't found a working way to use the PDM microphone with Python. You need to use the ADC pins, but still no luck.
    Using the PICO and audio , check this google colab
    https://colab.research.google.com/github/ArmDeveloperEcosystem/ml-audio-classifier-example-for-pico/blob/main/ml_audio_classifier_example_for_pico.ipynb
    It has everything you need to start your project - it's a perfect example of using a Raspberry PICO with a microphone and do some inference on it.
    It goes through all the steps - from data collecting, model creation and training and the steps to do inference on the pico.
    The google colab comes from this page
    Just try it !
  • Sudeep AJ
    Thank you very much for sharing these with me! I will surely try it.
  • bidrohini
    bidrohini over 3 years ago
    Can you suggest some machine learning projects that can be done with these tinyML models without using a camera? I have a Raspberry Pi Pico. I want to do ML projects with that. But all the suggestions I get are of camera based projects. I do not have a pico compatible camera.
    dougw over 3 years ago in reply to bidrohini
    https://www.youtube.com/watch?v=V0KXZGhHUQY&ab_channel=ArmSoftwareDevelopers
  • feiticeir0
    feiticeir0 over 3 years ago in reply to bidrohini
    On my comment above, there are sound projects.
    Here's one:
