Raspberry Pi Forum how to improve the brachioGraph project to make it special
  • Replies 12 replies
  • Subscribers 698 subscribers
  • Views 3461 views
  • rasp
  • servo
  • raspeberry_pi_accessories
  • electronics
samiboutgoulla
samiboutgoulla over 3 years ago
hello everyone I made a project www.brachiograph.art/.../construct.html brachioGraph with three servo motors and a raspberry pi, I need help to improve it, add something design thing, add something else that will make it betterf
  • colporteur
    0 colporteur over 3 years ago
    What is the end goal of the project? Is for school, personal interest, project for work....
    What made you chose this project to work on?
    0 dougw over 3 years ago
    It would benefit from more precise servos, but they are heavier, so the whole mechanism probably needs to get stronger.
  • ntewinkel
    0 ntewinkel over 3 years ago
    That’s a really cool project! Is that your video, or is that showing what your project needs to extend?
    You could make it larger, requiring some extra support for the outer servos, maybe like the way bridges have towers with wires going to the surface.
  • beacon_dave
    0 beacon_dave over 3 years ago
    I saw a similar design done in the early 80's, except they also had incorporated a second linkage with rotary encoders to be used as an input digitiser device.
    So the operator could trace an outline or draw freehand and the plotter would directly follow it like a telechir device.
    Also like a telechir device, the operator could add a scaling factor to enlarge or reduce the size of the output in relation to the input movements.
    Very similar to the pantograph drawing tools that had been a craze in the 70's (probably had influenced the project), however the input movements could also be captured, stored, edited, and then replayed over and over without any further user input (probably inspired by having to do 'lines' at school.).
  • beacon_dave
    You could try a rotary base design. One motor rotates the base with the paper and the other swings the pen arm in an arc from the outside to the centre. A bit like a hard disk drive or a phonograph tone arm.
    As each motor is fixed to the same base plate you might get a more rigid design.
    I've seen 'coaster plotters' done this way but they tend to use a linear lead screw arrangement to move the pen.
    0 Jan Cumps over 3 years ago in reply to beacon_dave
    If you could turn it into a gear works like this one, with drawing functionality incorporated, that would be spectacular (starts at 2:30: )
    Source: Syberia, the world before, by Belgian cartoonist Benoit Sokal
  • beacon_dave
    0 beacon_dave over 3 years ago in reply to Jan Cumps
    That looks more Spirograph than Sketch-A-Graph Slight smile
    Reminds me a bit of the kinetic sculptures by David Roy
    https://www.youtube.com/watch?v=P146sMmRwnI&list=PL2FC4A30A787F8B2B
    I think that the inspiration comes from the Tourbillon mechanism
    The Wankel engine of the watch world
    for the lovers of cameos, a snippet from that video:
    When I look outside my kitchen window:
    0 genebren over 3 years ago in reply to Jan Cumps
    Wow!
