Raspberry Pi Forum Power Raspberry PI using Solar Panel
  • Replies 41 replies
  • Subscribers 695 subscribers
  • Views 20895 views
  • solar panel raspberry pi
  • raspberry pi
  • power raspberry pi solar
feiticeir0
feiticeir0 over 3 years ago
Hi all.
Following a project - AllSky - taking photos all night at the sky - I want to place the PI - Raspberry PI 4 B+ 4GB memory using a SSD NVMe 512GB  - where I don't have a power outlet.
I've the following setup:
- Solar Panel -
  • max power: 20W
  • Vmpp: 18.2V
  • Voc: 22.6V
  • Impp: 1.12A
  • short-circuit: 1.18A
That connects to a Waveshare Solar Power Manager (C), that is powered by 3x 18650 batteries - each battery has 3350mAh - NCR18650B.
I've set the setup voltage switch for 12V - the same as the solar panel.
I don't have a problem with the charging. It charges very well, to full charge.
My problem is, it just wont last all night.
Starting to take pictures at 21:30 (9pm), it only lasts to (the last picture taken) 3:44 (3:44am) . Just over 6h.. This can't be right.
My question is - what can I do to make it last longer. Should I buy more powerful batteries - like 5000mAh or more ? Chose other solar charger ?
I have the Raspberry PI Lite version - and I've disabled some unwanted services like - bluetooth, avahi-daemon, triggerhappy, etc.. I even disabled the status LEDS... Slight smile
Any idea would be great.
Thank you
  • walkie919
    walkie919 10 months ago
    For anyone out there trying to build a similar project, this might be useful: www.kickstarter.com/.../pv-pi-power-your-raspberry-pi-with-the-sun
    Simplifies all of the power needs into a board compatible with the Raspberry Pi.
