Raspberry Pi Forum Pi Desktop power on
  • +1 person also asked this people also asked this
  • Replies 12 replies
  • Subscribers 697 subscribers
  • Views 3872 views
Pi Desktop power on
linuxneverdies
linuxneverdies over 3 years ago
Is it possible to let the raspi boot immediately after usb power is connected?
normally he waits for the button to be pressed.
    0 dougw over 3 years ago
    https://raspberrytips.com/autostart-a-program-on-boot/
  • feiticeir0
    0 feiticeir0 over 3 years ago
    Hi !
    What do you mean ?
    Usually when the PI receives power, unless some HAT is connected (the Pironman case is an example - you need to press the power button) the RPi starts booting...
    Again, what do you mean ?
  • linuxneverdies
    0 linuxneverdies over 3 years ago in reply to feiticeir0
    Hi, my raspi is in the element14 desktop case  /products/devtools/product-pages/w/documents/22485/desktop-computer-kit-for-raspberry-pi with a button on top. If I switch on power via USB the raspi is not booting. I have to press the button.
    I want to know if there is a configuration possibility that the raspi is directly booting without the need to press the button.
  • baldengineer
    0 baldengineer over 3 years ago in reply to linuxneverdies
    The confusion is because the case you're using has a microcontroller-based power circuit. So, there isn't a "Pi-based" solution to forcing it to turn on.
    Page 16 of the case's manual talks about the power circuit.
    So you would need to investigate that (non-standard) circuit further to force it to an on-state.
    • Vote Up +5 Vote Down
  • colporteur
    0 colporteur over 3 years ago
    You could remove the Pi from the desktop enclosure. This removes the constraints from the desktop enclosure. Why the necessity for immediate power up? That is typically something you don't want in a desktop.
  • linuxneverdies
    0 linuxneverdies over 3 years ago in reply to colporteur
    I use it as a server (nextCloud, piHole), but we switch the power strip off during night.
  • linuxneverdies
    0 linuxneverdies over 3 years ago in reply to baldengineer
    Yes, I thought so too, but I hoped there is a more simpler solution...
  • baldengineer
    +1 baldengineer over 3 years ago in reply to linuxneverdies
    So, the documentation page you linked to has a link to the product's GitHub repo.
    There, someone opened an issue for powering on after power loss (for example, after someone turns the power strip off and then back on.)
    It looks like a very small modification with a 10 uF electrolytic capacitor works for others.
    (Also, the code for the STM8 in the power control unit is there too. But not much about how to build and program the microcontroller, so that might be a tougher route.)
  • colporteur
    0 colporteur over 3 years ago in reply to baldengineer
    Great dumpster dive to find the details baldengineer!
  • linuxneverdies
    Thanks, that made my day Smiley!
