Raspberry Pi Forum 24v COB rgb 840 strip controled by Raspberry Pi
  • Replies 63 replies
  • Subscribers 698 subscribers
  • Views 11517 views
fskrzycki
fskrzycki over 3 years ago
I am having a hard time figuring out the solution to controlling my 24v strip with my Pi 4. I have a 4 pin strip with R. B. G. Bk wires.  I think a N-channel MOSFETs transistor will fix the communication issue and allow control of the colors. most Ara fruit software I have seen is for addressable Leds with only 3 leads. R. Bk. and Green.  Am I on the right track with using the transistors. If so Why? is there an easier way? I am making a bay blade stadium for my son and want to incorporate buttons with lights and sound..
  • fskrzycki
    fskrzycki over 2 years ago in reply to phoenixcomm
    1. i'm using optocouplers to isolate the pi from the LED power source. I needed to create 3 circuit boards, on for RBG.  i connected them together at the power source input of the zenner Diode.  Will this be a problem with galvanic isolation?  also, do Zenner Diodes need to be placed into the circuit a particular way?image
    2. imageimage
  • fskrzycki
    fskrzycki over 2 years ago in reply to fskrzycki
    Hey Shabaz,
    I  connected  all the zero volt grounds on tbe Zenner Diode side to the Power Supply Ground.
    I am seeing a large decrease in brightness when GPIO PIN IS SET High.
    I am able to control color frequency. so the optocoupler works!  awesome!
    unfortunately, I still have a leak because they gradually get brighter.
    I lowered the resistance after the optocoupler on the diode side to. 10k. no change.
    the leak must be on the diode side. Any suggestions?
  • fskrzycki
    fskrzycki over 2 years ago in reply to colporteur
    funny, I cannot find a single free Android circuit design application that includes an optocoupler.
