Raspberry Pi Forum LED Driver Circut
  • Replies 24 replies
  • Subscribers 695 subscribers
  • Views 4901 views
LED Driver Circut
fskrzycki
fskrzycki over 3 years ago
Can you review this circuit layout. Using Rasp pi to drive a high end LED strip. 24v mini 0402 LED.
I am experiencing a power leak on the board i built. I believe i need  resistance after my optocoupler on the Pi. side.
With the high voltage I am looking to protect the pi while still safely operating the strip.
i have changed 2 things on this board since the picture.  I now have all grounds on ths Zenner Diode side connected to power supply ground and I decreased the Resistor from. 100k to 10k on the advise of Open Ai
    shabaz over 3 years ago in reply to fskrzycki
    Just remembered I did a project with a Pi involving 24V lights in the past too, using perfboard, it is documented here:  Raspberry Pi enabled Christmas Lights   .
    However mine was lower power (about 2.8W per chain of lights, and there were 4 chains), and it used lamps instead of LEDs. It definitely helps using a larger board. This was 85 x 70 mm approx:
    Underside, using thin (30 AWG) bare wire, but it's possible to use solderable enamel wire etc. I used the perfboard mentioned above.
    However now PCBs are so cheap, if I were to do it again, I'd make a custom board.
  • scottiebabe
    scottiebabe over 3 years ago in reply to dang74
    lol in that photographed circuit above when the opto is switched off,  the FET's gate voltage is determined by in-circuit leakage currents...
  • fskrzycki
    fskrzycki over 3 years ago in reply to dang74
    i caught the mistake two nights ago when i was checking the Msft for connection problems to the 100k. i spent some time remaking a new circuit with care to insulate everything, even after cleaning the board with rubbing alcohol, but when i was finished, it still didn't operate correctly. my continuity was off all over the board. i had pin holes with no surrounding components giving charge.
  • fskrzycki
    fskrzycki over 3 years ago in reply to shabaz
    looks good, the boards i have now are traceable on both sides. My plan was to connect all three and run grounds together and power together. I ruined my week by losing my galvanic isolation Stuck out tongue
