Raspberry Pi Forum What are some random uses for a RPI Pico?
  • Replies 27 replies
  • Subscribers 699 subscribers
  • Views 5917 views
scottiebabe
scottiebabe over 2 years ago
Everyone Heart's the RPI Pico!
-Power Supply (The pico has a buck-boost DCDC converter outputting 3.3V @ 1A)
-USB Serial Adapter (use the https://github.com/raspberrypi/picoprobe firmware for a USB-Uart Converter, no more FTDI breakout boards!)
-Logic analyzer https://github.com/pico-coder/sigrok-pico
-Oscilloscope https://github.com/fhdm-dev/scoppy
-Microphone
Jan's USBTMC DAQ
What's your favorite random use for a Pico
  • dang74
    dang74 over 2 years ago in reply to beacon_dave
    Thanks for the link.  Very cool indeed.
  • dang74
    dang74 over 2 years ago in reply to feiticeir0
    Nice. Slight smile
  • ntewinkel
    ntewinkel over 2 years ago in reply to feiticeir0
    One day she’s going to figure out how to wire up an air horn to those Picos Scream Joy
  • Workshopshed
    Workshopshed over 2 years ago
    My random Pico projects include a controller for Halloween effects, Fizz Buzz game and remote sensor
  • scottiebabe
    I can reply here?
    Vernit gave me Zipper mouth over github link Tada
    My fault I used the raw link https:// raw dot githubusercontent dot com/
  • scottiebabe
    scottiebabe over 2 years ago in reply to scottiebabe
    Using RPI Python Calculator for now: *snip* https://github.com/raspberrypi/pico-sdk/blob/master/src/rp2_common/hardware_clocks/scripts/vcocalc.py
    @micropython.native
    def calc(output,input=12,ref_min=5,vco_max=1600,vco_min=750,low_vco=False):
        # Fixed hardware parameters
        fbdiv_range = range(16, 320 + 1)
        postdiv_range = range(1, 7 + 1)
        ref_min = 2#5
        refdiv_min = 1
        refdiv_max = 63
        refdiv_range = range(refdiv_min, max(refdiv_min, min(refdiv_max, int(input / ref_min))) + 1)
        best = (0, 0, 0, 0, 0)
        best_margin = output
        for refdiv in refdiv_range:
            for fbdiv in (fbdiv_range if low_vco else reversed(fbdiv_range)):
                vco = input / refdiv * fbdiv
                if vco < vco_min or vco > vco_max:
                    continue
                # pd1 is inner loop so that we prefer higher ratios of pd1:pd2
                for pd2 in postdiv_range:
                    for pd1 in postdiv_range:
                        out = vco / pd1 / pd2
                        margin = abs(out - output)
                        if margin < best_margin:
                            best = (out, fbdiv, pd1, pd2, refdiv)
                            best_margin = margin
        print("Requested: {} MHz".format(output))
        print("Achieved: {} MHz".format(best[0]))
        print("Error: {} MHz".format(best[0]-output))
        print("REFDIV: {}".format(best[4]))
        print("FBDIV: {} (VCO = {} MHz)".format(best[1], input / best[4] * best[1]))
        print("PD1: {}".format(best[2]))
        print("PD2: {}".format(best[3]))
        return {'REFDIV':best[4], 'FBDIV':best[1], 'PD1':best[2], 'PD2':best[3]}
    And 200 MHz
    DAB over 2 years ago
    I have started to play around with the PICO and it can be a very good general purpose MCU for a lot of different applications.
