Raspberry Pi Forum Jazz up your Project with an Extruded Aluminum Enclosure
  • Replies 24 replies
  • Subscribers 694 subscribers
  • Views 5308 views
scottiebabe
scottiebabe over 2 years ago
Unbeknownst to the reader, this project is actually a $4 piece of junk. At a casual glance, you may be tempted to believe it is boutique product.
Ooh ahh, fancy. I purchased one of these extruded aluminum enclosure from a local seller.
Photos curtesy of this product listing: https://www.aliexpress.com/item/33053448840.html
I cut 2 pieces of bare copper clad board to fit within the PCB mounting channels of the enclosure.
I used my Dremel to drill 4 mounting holes aligned to 4 ground pins on the edge connectors of the Pico.
I don’t use the drill press stand attachment to my Dremel enough to have a strong opinion about it. There are fancier model making precision drill presses, but I already have this so I use it.
The Pico soldered to a carrier card
To machine out the microUSB connector slot, I first a put a piece of blue tape on the enclosure endplate and made an impression of the connector.
I then drilled and filled the slot large enough such that the USB connector could slide right through.
Not perfect, but close enough for my standards.
Similar process for the SMA connectors.
The 2 pushbuttons were a very long and tedious process. I drilled the holes first and then tried to solder the buttons to match the holes. I used what I had at hand, but this process could be avoided entirely using proper pushbutton and a custom PCB. But, in the end I got it to fit together fairly well.
The second prototype card
It is just an amplifier/buffer using a screaming fast hex logic inverter.
In the end I have a little CW signal generator capable of tuning from DC to 200 MHz and provides an output power of ~13.5 dBm into 50 Ohms.
Conclusion
The end result looks fabulous on the exterior.
Locating and machining the cutouts for the USB connector and SMA connector were relatively easy.
There is ample room for prototype style construction and a RPI Pico.
Using this style of enclosure is a lot more work as apposed to loosely tossing everything in a box and using panel mount connectors and interface elements. Wherever you drilled the hole, is where the connector ends up.
If your going to go to the trouble of making a custom PCB, you could make a printable drill template for the endplates. Or spend even more and order custom endplates using a PCB or aluminum.
Happy tinkering!
  • scottiebabe
    Something similar from the Newark catalog might be the: Hammond 06X3882   https://www.farnell.com/datasheets/1707275.pdf
    I liked that the enclosure was large enough but also not too large like a effects pedal die cast box.
    It isn't too much larger than a RPI Pico
    genebren over 2 years ago
    I absolutely love the bare copper prototype with the flying wire work on the hex inverter!  Well done.
  • anniel747
    anniel747 over 2 years ago in reply to genebren
    [deleted]
  • scottiebabe
    scottiebabe over 2 years ago in reply to genebren
    Thanks for the kind words, I agree the construction as a very unique look Slight smile
  • scottiebabe
    scottiebabe over 2 years ago in reply to anniel747
    The DIP cheetah pose? Not sure...
  • scottiebabe
    Lots of great tips here as well
     Building a Unique USB Card Reader: From Idea to Prototype -- Episode 615
  • beacon_dave
    beacon_dave over 2 years ago in reply to scottiebabe
    'you're gonna need a bigger box' if you are going to fit that in it... Slight smile
    Jan Cumps over 2 years ago in reply to beacon_dave
  • beacon_dave
    beacon_dave over 2 years ago in reply to Jan Cumps
    That brings back memories. You used to get fake tails when you filled up at the petrol station (gas station) that you were supposed to attach to your filler cap as a marketing ploy. Later on the auto jumbles at car shows used to have hundreds of them decorating stalls like bunting.
  • anniel747
    anniel747 over 2 years ago in reply to Jan Cumps
    [deleted]
