Raspberry Pi Forum Interfacing Raspberry Pi 5G HAT with other controller
  • Replies 33 replies
  • Subscribers 699 subscribers
  • Views 6243 views
meera_hussien
meera_hussien over 2 years ago
Gooday,
I am trying to interface the 5G HAT module with the XIAO ESP32C3 module through the UART and also through the USB to TTL, but both are unsuccessful.
Has anyone tried this method? Or is there a different method that can be used?
Below is the 5G HAT that i am using
https://www.waveshare.com/wiki/RM500Q-GL_5G_HAT.
Appreciate if anyone can help on this
    0 shabaz over 2 years ago in reply to meera_hussien
    Unfortunately this is not something I have done, so I cannot help : ( I have never worked with GSM : (
    With 4G/LTE modules which I have tried, with variants like LTE-M that might be supported by some modules, you'd have to examine the module AT command datasheet, they ought to have some examples (for various clouds). You may need to reach out to the manufacturer if you're deviating from their examples in their AT command documentation. It won't be entirely straightforward, you may also need to talk to whichever software engineer is coding the cloud side. I've not tried a 5G module.
  • meera_hussien
    0 meera_hussien over 2 years ago in reply to balajivan1995
    Thanks balajivan1995 . Will try and update back here.
  • meera_hussien
    0 meera_hussien over 2 years ago in reply to shabaz
    Thank you shabaz . Will check with the manufacturer and see how i can get the things to work.
