Raspberry Pi Forum Cheap WiFi / BLE Antennas
  • Subscribers 698 subscribers
  • Views 1514 views
  • ble
  • wifi
  • antenna
shabaz
shabaz over 2 years ago
I don't know how long they have been available, but anyone noticed that Raspberrypi.com do cheap antennas?: Mnfr product code SC0480 .
It is intended for the Pi Compute Module 4 according to the datasheet, but that's no reason not to use it for other purposes.
The antenna is approx 108 mm long. The supplied cable has about 180 mm of coax between the end connectors.
The cable has a U.FL connector at one end. Annoyingly, the other connection on the cable/antenna is reverse-polarity SMA (i.e., RP-SMA) and not normal SMA (it's because these are low-cost consumer antennas, so RP-SMA will prevent users from attaching higher-gain antennas to the connector. Still, it's a bit weird because I thought most Compute Module use-cases would be industrial/enterprise, not consumer-oriented).
Still, not bad for the low price if you need a WiFi and/or BLE antenna.
  • mp2100
    mp2100 over 2 years ago
    Good find. I don’t need these ATM but it’s good to know they’re available.
    DAB over 2 years ago
    Nice find.
  • obones
    obones over 1 year ago
    Nice.
    Now, on to find a way to attach this to an ESP32 board with an integrated antenna and no UFL connector...
    shabaz over 1 year ago in reply to obones
    That will be not easy, however there are some ESP modules with U.FL connector instead, but otherwise compatible, so that could be an option too.
    I ended up using a couple of these raspberrypi antennas for Bluetooth audio. I retrofitted Bluetooth audio input into a 1990's Pioneer Hi-Fi separates system for a friend (and stuck a metallic Bluetooth sticker on the Tape 2 button, it's now doing a much more useful thing!). And retrofitted an ultra-high-end Pioneer car stereo too (it's got a glowing valve/tube at the front..).
    I didn't take any or many photos unfortunately, and am away from PC to check, otherwise I would have shared a photo.
    shabaz over 1 year ago in reply to shabaz
    Photo of the Hi-Fi upgrade..
    The Bluetooth board is visible at the left side, It's on a custom board with custom power supply etc. I put the Pioneer logo onto the copper layer (gold plating to look nice!). At the top of the photo there is a non-flammable plastic cover over the terminals, to prevent anyone electrocuting themselves with their finger etc even if they open the chassis.
    The power regulator feeding the Bluetooth board:
    These are the only photos I have : (
    genebren over 1 year ago in reply to shabaz
    Very cool! This turned out really nice.
