Raspberry Pi Forum PyVisa | Trouble | Identifying Resources | Pi4
  • Subscribers 702 subscribers
  • Views 1255 views
SAClifford
SAClifford over 1 year ago
I am trying to us a Raspberry Pi4 to to send SCPI commands to a Chroma 61602 and a ITECH IT8512G+ but I can never get PyVisa ResourceManager to return any thing.  My return is ()
I am communicating to both instruments with USB connections.  When I do a isusb command on my terminal both devices do show up on each port.
Below is my code and the Terminal response I receive. I have tried for several days now and I can never get a Resource Manger response from the two instruments connected to my Pi4 USB ports.  My hope is someone has seen this before and can offer me some assistance.
Python Code:
import pyvisa
from time import sleep
#" Chroma 61602 and ITECH IT8512G+ Comm Check"
rm = pyvisa.ResourceManager()
print(rm.list_resources())
Terminal Output when ran:
(venv-psu) eng@psupi:~/PSU-Test $ /home/eng/PSU-Test/venv-psu/bin/python /home/eng/PSU-Test/Comm_Test.py
  • bidrohini
    0 bidrohini over 1 year ago
    Check if libusb or NI-VISA libraries are installed. Try installing libvisa via:
    sudo apt install libusb-1.0-0-dev
  • colporteur
    0 colporteur over 1 year ago in reply to bidrohini
    Sounds like a voice of experience.
  • SAClifford
    0 SAClifford over 1 year ago
    Thank you for trying to help me in my effort to try and get two instruments on USB ports to respond to the pyvisa command.  I did as you suggested and installed libusb-1.0-0-dev, but I still get the same response () of nothing.
    0 shabaz over 1 year ago
    You should try a PC, just to confirm if it's a issue with the Pi setup, or with the instrument.
    Does it work with Windows? Can you use any known working software application to send the IDN? query and successfully see a response?
