Raspberry Pi Forum Raspberry Pi Project with Fingerprint Sensor and Battery Backup
  • Subscribers 701 subscribers
  • Views 1268 views
  • project
  • rpibeginner
  • raspberry pi
  • raspberry-pi
  • raspberrypi
  • raspberry_pi_projects
  • rpi_projects
omega_apex128
omega_apex128 over 1 year ago
I'm very excited as this is my first time taking on a big task.  I'm a senior in my college's EEE program and am trying to come up with an interesting design but the struggle has been real.  At the moment I'm working on implementing a fingerprint sensor with a Raspberry Pi 4 onto a kiosk that I will demo but the brunt of my demo is the battery backup system.  I've designed it so that in the event of a sudden power failure, the system will continue to work for a few hours uninterrupted.  The trouble now is actually getting it to function.  I don't know if its because I've been staring at the project in the face for the past week or if I've even been staring and working on it for the past 12 hours now, but I simply cannot get the, in my eyes, most simplest of ideas to work.  It's all sound in theory but there just must be something I'm overlooking.  I just wish I knew what it was.  I'm sure I'm not the only person that has done this.  A lot of the parts have come on modules already built so they already have the necessary resistors and capacitors and what not.  Sure I had to do some calculations to make sure nothing was getting eaten up and I didn't see anything out of the ordinary...but man...the struggle is real. I guess this is what awaits me.  How does one cope with these struggles?  Especially on time crunch deadlines.  I could use some coffee and a chiropractor.
  • bidrohini
    bidrohini over 1 year ago
    Sometimes the best way to solve a problem is to step away from it. Even a 15-30 minute walk or a short nap can help reset your mind and provide new insights.
    Jan Cumps over 1 year ago
    If I read well, you are struggling with the power supply? There are a number of uninterruptible power supply (UPS) hats for Pi. You could check out how they are designed, and learn from that.
    And coffee.
    dougw over 1 year ago
    A simple UPS is to run your project off a battery and have the battery be continuously charged from the mains. When the mains fail, the system continues to run off the battery. If you show what your circuit looks like more help would be available.
  • colporteur
    colporteur over 1 year ago in reply to dougw
    I have done a simple test like this. Use one line in cron to write Date to file. Run Pi on battery until dead. You see first hand results of running the system under load and what you need for sizing
