Raspberry Pi Forum Programming MAX96717F and MAX96714F
  • Replies 9 replies
  • Subscribers 701 subscribers
  • Views 1761 views
  • gmsl2
  • MAX96717F
  • MAX96714f
bugtech
bugtech over 1 year ago
HI,
I am using SerDes MAX96717F Ser and MAX96714F Des (MAXIM INTEGRATED) along with raspberry pi 4 to get the output of Raspi Camera on RPi4.
1: The pipeline has been generated using the GMSL gui through script generation.
2: Once cpp file is loaded, i am able to get the display at the Rpi4.
The issue is whenever i power cycle the boards. I need to load the script again to get the output.
How can i program it for once and use it even after power cycle?
Any leads?
  • aswinvenu
    0 aswinvenu over 1 year ago
    You can either use init.d scripts or create a service with systemd and enable the service ( which will make it run everytime after the boot process ).
    Init.d scripts:
    https://xdaforums.com/t/guide-how-to-make-an-init-d-script-noob-friendly.2326585/
    systemd service.
    https://medium.com/@benmorel/creating-a-linux-service-with-systemd-611b5c8b91d6
  • colporteur
    0 colporteur over 1 year ago
    There are a number of ways to run a script on boot from the Raspberry Pi O/S.
    Using crontab
    Using autostart
    Using .bashrc
    Using systemd
    Using rc.local
    Using init.d
    I feel the last two are old school with little support. You may find they work but I find instructions that date around 2013 cause me to questions is it appropriate.
    I've used all of them at some point in time depending on what I am trying to do.
    0 shabaz over 1 year ago
    As mentioned by aswinvenu  and colporteur this is really a Linux thing and there are several techniques you could use.
    If this is for a commercial product, it would be highly recommended to get some Linux training (good for career in general, but relevant in this case as you've discovered). Something like a Linux Sysadmin course would be a good start (although a developer who has written Linux based apps would be good to hire too).
    I'm not mentioning this to suggest online support doesn't help, because it clearly does, but that you may be missing things relevant for your Linux application, installation, performance, and so many other things otherwise.
    +1 Jan Cumps over 1 year ago
    A short guide that will work on the PI OSes. It uses systemd. (summary of an e14 project that uses system services)
    • create a service script
    sudo nano /etc/systemd/system/raspicam.service
    [Unit]
    Description=Raspberry Pi camera service
    After=network-online.target
    Wants=network-online.target
    [Service]
    Type=simple
    WorkingDirectory=/<path to where you want the software to run>
    ExecStart=/<command line of script / program to run. Can include parameters>
    Restart=always
    RestartSec=30
    StandardOutput=syslog
    StandardError=syslog
    SyslogIdentifier=raspicam
    User=<yourname>
    Group=<yourname>
    [Install]
    WantedBy=multi-user.target
    • register it
    sudo systemctl daemon-reload
    • enable and start
    sudo systemctl enable raspicam.service
    sudo systemctl start raspicam.service
    • check status:
    systemctl status raspicam.service
    This will start the program, running as the user you put in the script. If for some reason you want to run it as root*, remove the User and Group lines.
    • Vote Up +5 Vote Down
  • bugtech
    0 bugtech over 1 year ago in reply to aswinvenu
    aswinvenu Thank you for your support!
  • bugtech
    0 bugtech over 1 year ago in reply to colporteur
    colporteur Thank you for your support!
  • bugtech
    0 bugtech over 1 year ago in reply to Jan Cumps
    Jan Cumps Thank you for your support! It works without any trouble. Not related but, I would like to know if it is possible to achieve same task in Petalinux 2022.2? Thanks again!
    0 Jan Cumps over 1 year ago in reply to bugtech
    I don't know Slight smile
    I have made a Vivado / Petalinux project a few years ago, just to try it out. But I never dug into many topics. Just to see if I could get it working.
  • bugtech
    Appreciate your response!
