Raspberry Pi Forum Cirrus Logic Audio Card with JACK
  • Subscribers 706 subscribers
  • Views 663 views
  • raspeberry_pi_accessories
Hi All
I am now using JACK with Cirrus logic audio card on RPI2. When I start qjackctl, there is an error that cannot find capture device. I exactly followed the user manual to setup RPI2. How can I fixed it problem. Thank you.
  • clem57
    clem57 over 10 years ago
    Looking at QjackCtl - JACK Audio Connection Tookit - Qt GUI Interface , I would check the requirements and install first. If all appears correct, then use the support to send a detailed explanation and codes seen. Good luck.
    Clem
  • librears
    librears over 10 years ago
    Are there some news? I also try to use JACK on the rpi2.
    I installed jackd2 (sudo apt-get install) and typed 'sudo jackd -d alsa hw:sndrpiwsp'. This is what I got:
    jackdmp 1.9.10
    Copyright 2001-2005 Paul Davis and others.
    Copyright 2004-2014 Grame.
    jackdmp comes with ABSOLUTELY NO WARRANTY
    This is free software, and you are welcome to redistribute it
    under certain conditions; see the file COPYING for details
    JACK server starting in realtime mode with priority 10
    self-connect-mode is "Don't restrict self connect requests"
    Failed to connect to session bus for device reservation Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
    Audio device hw:0 cannot be acquired...
    Cannot initialize driver
    JackServer::Open failed with -1
    Failed to open server
    There was a discussion about this for the B+ Cirrus Audio, B+, and Jack?? but it seems not to work on the rpi2.
    Is there someone successfully running jack on the rpi2?
  • librears
    librears over 10 years ago in reply to librears
    Jack works now. I found the solution on: https://journeytounknownsoundscapes.blogspot.de/2015/05/a-new-looper-in-town-raspberry-pi-with.html
    Before starting Jack execute in your terminal:
    export DISPLAY=:0
    export dbus-launch | grep ADDRESS
