Raspberry Pi Forum Raspberry pi composite vidoe issues
  • Subscribers 707 subscribers
  • Views 807 views
  • raspberrypi1b
  • pi
  • issues
  • raspberry pi b
Hi im making raspberry pi portable.Im using raspberry pi 1 B.Ihave issues with composte video dosent work on raspbian.I tried uncommenting hdmi hotplug and disconected hdmi when booting but it didnt work .If you know a solution please help me thanks for all help.
  • clem57
    clem57 over 10 years ago
    For this situation check the cable. This picture details what the 4 rings maybe. In one case the ground is in wrong position and WILL NOT work(MP3 player).
    Clem
  • rew
    rew over 10 years ago in reply to clem57
    Also... In the beginning, if there was nothing connected to HDMI, the pi would switch to TV mode automatically. But nowadays, IIRC, you need to specify explicitlyA in config.txt that you want TV output enabled....
    Hmm. if you say you remove the HDMI cable, that means you at least HAVE an HDMI monitor. So then you can log in and use the "tvservice" program to set the mode. Look in the manual or help for what you need to specify for TV mode.
    e14 Contributor over 10 years ago in reply to clem57
    im using raspberry pi 1b and cable works for sure i used it with OSMC and now im doing what people sugested on this forum and i have an image
    raspbian - The Composite Video on my Raspberry Pi isn't working - Raspberry Pi Stack Exchange
