Raspberry Pi Forum Speakers Problem with Cirrus Logic
  • Subscribers 706 subscribers
  • Views 994 views
  • raspeberry_pi_accessories
I am using Cirrus Logic audio board with Raspberry Pi 2. I managed to test the Cirrus Logic with my headphone with the script:
./Reset_paths.sh
./Playback_to_Lineout.sh
The problem that I didn't manage to use the Cirrus Logic with my speakers which I have already soldered them in J3 and J6.
I used the scripts:
./Reset_paths.sh
./Playback_to_Speakers.sh
Here you are the traces of the GPU, kernel and loadble modules:
pi@raspberrypi:~ $ paste /boot/config.txt
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=1000
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
#dtparam=audio=on
start_x=1
gpu_mem=128
core_freq=500
sdram_freq=500
over_voltage=2
#dtoverlay=hifiberry-dacplus
#force_eeprom_read=0
dtoverlay=rpi-cirrus-wm5102
dtoverlay=i2s-mmap
dtdebug=1
pi@raspberrypi:~ $ vcgencmd version | paste
Jul 28 2016 12:46:32
Copyright (c) 2012 Broadcom
version e12916091ba9d68ef2780e4e142ade56aa301754 (clean) (release)
pi@raspberrypi:~ $ sudo vcdbg log msg 2>&1 | paste
000874.385: HDMI:EDID error reading EDID block 0 attempt 0
000875.649: HDMI:EDID error reading EDID block 0 attempt 1
000876.908: HDMI:EDID error reading EDID block 0 attempt 2
000878.166: HDMI:EDID error reading EDID block 0 attempt 3
000879.424: HDMI:EDID error reading EDID block 0 attempt 4
000880.682: HDMI:EDID error reading EDID block 0 attempt 5
000881.940: HDMI:EDID error reading EDID block 0 attempt 6
000883.199: HDMI:EDID error reading EDID block 0 attempt 7
000884.458: HDMI:EDID error reading EDID block 0 attempt 8
000885.716: HDMI:EDID error reading EDID block 0 attempt 9
000886.738: HDMI:EDID giving up on reading EDID block 0
000899.713: HDMI:Setting property pixel encoding to Default
000899.734: HDMI:Setting property pixel clock type to PAL
000899.751: HDMI:Setting property content type flag to No data
000899.771: HDMI:Setting property fuzzy format match to enabled
000907.264: gpioman: gpioman_get_pin_num: pin BT_ON not defined
000907.284: gpioman: gpioman_get_pin_num: pin WL_ON not defined
001097.153: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001097.179: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
001097.560: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
001098.827: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
001100.091: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
001101.354: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
001102.617: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
001103.880: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
001105.143: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
001106.406: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
001107.669: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
001108.932: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
001109.958: hdmi: HDMI:EDID giving up on reading EDID block 0
001109.993: hdmi: HDMI: No lookup table for resolution group 0
001110.010: hdmi: HDMI: hotplug attached with DVI support
001110.069: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001110.430: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
001111.691: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
001112.952: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
001114.213: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
001115.474: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
001116.735: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
001117.996: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
001119.257: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
001120.518: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
001121.779: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
001122.803: hdmi: HDMI:EDID giving up on reading EDID block 0
001122.866: hdmi: HDMI: hotplug deassert
001122.881: hdmi: HDMI: HDMI is currently off
001122.896: hdmi: HDMI: changing mode to unplugged
001122.918: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001123.703: *** Restart logging
001124.994: Read command line from file 'cmdline.txt'
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
001399.964: Loading 'kernel7.img' to 0x8000 size 0x40d448
001403.608: Kernel trailer DTOK property says yes
001403.621: Kernel trailer DDTK property says yes
001406.278: Loading 'bcm2709-rpi-2-b.dtb' to 0x415448 size 0x38e7
001416.507: dtdebug: delete_node(/__local_fixups__)
001422.314: dtdebug: /aliases:i2c_vc=i2c0
001427.418: dtdebug: /__symbols__:i2c_vc=i2c0
001431.641: dtdebug: /__overrides__:i2c_vc=i2c0
001439.724: dtdebug: /__overrides__:i2c_vc_baudrate=i2c0_baudrate
001442.640: dtdebug: /aliases:i2c=i2c1
001447.903: dtdebug: /__symbols__:i2c=i2c1
001452.218: dtdebug: /__overrides__:i2c=i2c1
001455.177: dtdebug: /aliases:i2c_arm=i2c1
001460.481: dtdebug: /__symbols__:i2c_arm=i2c1
001464.836: dtdebug: /__overrides__:i2c_arm=i2c1
001473.106: dtdebug: /__overrides__:i2c_baudrate=i2c1_baudrate
001481.395: dtdebug: /__overrides__:i2c_arm_baudrate=i2c1_baudrate
001481.414: dtparam: pwr_led_gpio=35
001484.260: dtdebug: Found override pwr_led_gpio
001484.304: dtdebug:   override pwr_led_gpio: cell target gpios @ offset 4 (size 4)
001490.274: dtparam: uart0_clkrate=3000000
001492.987: dtdebug: Found override uart0_clkrate
001493.036: dtdebug:   override uart0_clkrate: cell target clock-frequency @ offset 0 (size 4)
001513.017: dtdebug: Opened overlay file 'overlays/rpi-cirrus-wm5102.dtbo'
001535.439: Loaded overlay 'rpi-cirrus-wm5102'
001535.493: dtdebug: Found fragment 0 (offset 36)
001535.584: dtdebug: merge_fragment(/,/fragment@0/__overlay__)
001535.806: dtdebug: merge_fragment(/aliases,/fragment@0/__overlay__/aliases)
001535.831: dtdebug:   +prop(ldo0)
001538.255: dtdebug:   +prop(ldo1)
001540.708: dtdebug: merge_fragment() end
001540.732: dtdebug: merge_fragment() end
001540.803: dtdebug: Found fragment 1 (offset 196)
001544.917: dtdebug: merge_fragment(/soc/i2s@7e203000,/fragment@1/__overlay__)
001544.942: dtdebug:   +prop(status)
001546.350: dtdebug: merge_fragment() end
001546.408: dtdebug: Found fragment 2 (offset 272)
001549.226: dtdebug: merge_fragment(/soc/gpio@7e200000,/fragment@2/__overlay__)
001552.071: dtdebug: merge_fragment(/soc/gpio@7e200000/wlf_pins,/fragment@2/__overlay__/wlf_pins)
001552.095: dtdebug:   +prop(brcm,pins)
001553.692: dtdebug:   +prop(brcm,function)
001555.299: dtdebug:   +prop(phandle)
001556.886: dtdebug: merge_fragment() end
001556.912: dtdebug: merge_fragment() end
001556.985: dtdebug: Found fragment 3 (offset 420)
001557.623: dtdebug: merge_fragment(/soc,/fragment@3/__overlay__)
001564.119: dtdebug: merge_fragment(/soc/ldo1,/fragment@3/__overlay__/ldo1)
001564.143: dtdebug:   +prop(compatible)
001565.780: dtdebug:   +prop(regulator-name)
001567.808: dtdebug:   +prop(regulator-min-microvolt)
001569.855: dtdebug:   +prop(regulator-max-microvolt)
001571.934: dtdebug:   +prop(enable-active-high)
001574.047: dtdebug:   +prop(regulator-always-on)
001576.162: dtdebug:   +prop(phandle)
001577.953: dtdebug: merge_fragment() end
001584.571: dtdebug: merge_fragment(/soc/ldo0,/fragment@3/__overlay__/ldo0)
001584.595: dtdebug:   +prop(compatible)
001586.259: dtdebug:   +prop(regulator-name)
001588.320: dtdebug:   +prop(regulator-min-microvolt)
001590.408: dtdebug:   +prop(regulator-max-microvolt)
001592.510: dtdebug:   +prop(enable-active-high)
001594.637: dtdebug:   +prop(regulator-always-on)
001596.773: dtdebug:   +prop(phandle)
001598.579: dtdebug: merge_fragment() end
001598.610: dtdebug: merge_fragment() end
001598.705: dtdebug: Found fragment 4 (offset 752)
001603.537: dtdebug: merge_fragment(/soc/spi@7e204000,/fragment@4/__overlay__)
001603.562: dtdebug:   +prop(#address-cells)
001604.947: dtdebug:   +prop(#size-cells)
001606.351: dtdebug:   +prop(status)
001609.545: dtdebug: merge_fragment(/soc/spi@7e204000/spidev@0,/fragment@4/__overlay__/spidev@0)
001609.571: dtdebug:   +prop(status)
001611.055: dtdebug: merge_fragment() end
001612.986: dtdebug: merge_fragment(/soc/spi@7e204000/spidev@1,/fragment@4/__overlay__/spidev@1)
001613.009: dtdebug:   +prop(status)
001614.478: dtdebug: merge_fragment() end
001617.860: dtdebug: merge_fragment(/soc/spi@7e204000/wm5102@1,/fragment@4/__overlay__/wm5102@1)
001617.887: dtdebug:   +prop(compatible)
001619.230: dtdebug:   +prop(reg)
001620.634: dtdebug:   +prop(#address-cells)
001621.993: dtdebug:   +prop(#size-cells)
001623.375: dtdebug:   +prop(spi-max-frequency)
001624.911: dtdebug:   +prop(interrupt-parent)
001626.312: dtdebug:   +prop(interrupts)
001627.784: dtdebug:   +prop(LDOVDD-supply)
001629.607: dtdebug:   +prop(AVDD-supply)
001631.450: dtdebug:   +prop(DBVDD1-supply)
001633.317: dtdebug:   +prop(DBVDD2-supply)
001635.196: dtdebug:   +prop(DBVDD3-supply)
001637.092: dtdebug:   +prop(CPVDD-supply)
001639.008: dtdebug:   +prop(SPKVDDL-supply)
001640.949: dtdebug:   +prop(SPKVDDR-supply)
001642.899: dtdebug:   +prop(wlf,reset)
001644.867: dtdebug:   +prop(wlf,ldoena)
001646.851: dtdebug:   +prop(wlf,gpio-defaults)
001648.851: dtdebug:   +prop(wlf,micd-configs)
001650.876: dtdebug:   +prop(wlf,dmic-ref)
001652.931: dtdebug:   +prop(wlf,clk32k-src)
001654.997: dtdebug:   +prop(wlf,inmode)
001657.089: dtdebug:   +prop(status)
001658.858: dtdebug: merge_fragment() end
001658.918: dtdebug: merge_fragment() end
001659.052: dtdebug: Found fragment 5 (offset 1416)
001667.464: dtdebug: merge_fragment(/soc/i2c@7e804000,/fragment@5/__overlay__)
001667.490: dtdebug:   +prop(status)
001668.631: dtdebug:   +prop(#address-cells)
001669.757: dtdebug:   +prop(#size-cells)
001674.944: dtdebug: merge_fragment(/soc/i2c@7e804000/wm8804@3b,/fragment@5/__overlay__/wm8804@3b)
001674.971: dtdebug:   +prop(#sound-dai-cells)
001676.193: dtdebug:   +prop(compatible)
001677.296: dtdebug:   +prop(reg)
001678.459: dtdebug:   +prop(status)
001679.668: dtdebug:   +prop(PVDD-supply)
001681.219: dtdebug:   +prop(DVDD-supply)
001682.820: dtdebug:   +prop(wlf,reset-gpio)
001684.454: dtdebug: merge_fragment() end
001684.487: dtdebug: merge_fragment() end
001684.571: dtdebug: Found fragment 6 (offset 1676)
001695.598: dtdebug: merge_fragment(/soc/sound,/fragment@6/__overlay__)
001695.625: dtdebug:   +prop(compatible)
001696.504: dtdebug:   +prop(i2s-controller)
001697.864: dtdebug:   +prop(status)
001698.735: dtdebug: merge_fragment() end
001703.831: dtdebug: Opened overlay file 'overlays/i2s-mmap.dtbo'
001709.119: Loaded overlay 'i2s-mmap'
001709.177: dtdebug: Found fragment 0 (offset 36)
001713.503: dtdebug: merge_fragment(/soc/i2s@7e203000,/fragment@0/__overlay__)
001713.529: dtdebug:   +prop(brcm,enable-mmap)
001715.600: dtdebug: merge_fragment() end
001719.856: dtdebug: /aliases:serial0=uart0
001723.208: dtdebug: /aliases:serial1=uart1
001775.914: dtparam: arm_freq=1000000000
001778.959: dtdebug: Found override arm_freq
001779.009: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
001789.256: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
001799.603: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
001810.035: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
001820.544: dtparam: core_freq=500000000
001823.723: dtdebug: Found override core_freq
001823.772: dtdebug:   override core_freq: cell target clock-frequency @ offset 0 (size 4)
001832.400: dtparam: cache_line_size=64
001835.445: dtdebug: Found override cache_line_size
001835.494: dtdebug:   override cache_line_size: cell target cache-line-size @ offset 0 (size 4)
001844.378: dtdebug: delete_node(/hat)
001851.765: Device tree loaded to 0x2fffbc00 (size 0x43ce)
001854.921: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
004334.842: vchiq_core: vchiq_init_state: slot_zero = 0xf6c80000, is_master = 1
004338.913: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
pi@raspberrypi:~ $ dmesg | paste
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.14-v7+ (hias@camel2) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1 SMP Mon Jul 4 19:20:47 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[    0.000000] cma: Reserved 8 MiB at 0x36800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 225280
[    0.000000] free_area_init_node: node 0, pgdat 808d1400, node_mem_map b6036000
[    0.000000]   Normal zone: 1980 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 225280 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 13 pages/cpu @b5ff2000 s22592 r8192 d22464 u53248
[    0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 223300
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x8bebfb63 smsc95xx.macaddr=B8:27:EB:EB:FB:63 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 874056K/901120K available (6384K kernel code, 434K rwdata, 1732K rodata, 480K init, 764K bss, 18872K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xb7800000 - 0xff800000   (1152 MB)
    lowmem  : 0x80000000 - 0xb7000000   ( 880 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807f530c   (8117 kB)
      .init : 0x807f6000 - 0x8086e000   ( 480 kB)
      .data : 0x8086e000 - 0x808da878   ( 435 kB)
       .bss : 0x808dd000 - 0x8099c22c   ( 765 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000031] Switching to timer-based delay loop, resolution 52ns
[    0.000350] Console: colour dummy device 80x30
[    0.001582] console [tty1] enabled
[    0.001636] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001715] pid_max: default: 32768 minimum: 301
[    0.002130] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002182] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003397] Disabling cpuset control group subsystem
[    0.003478] Initializing cgroup subsys io
[    0.003539] Initializing cgroup subsys memory
[    0.003617] Initializing cgroup subsys devices
[    0.003670] Initializing cgroup subsys freezer
[    0.003719] Initializing cgroup subsys net_cls
[    0.003813] CPU: Testing write buffer coherency: ok
[    0.003928] ftrace: allocating 21380 entries in 63 pages
[    0.056710] CPU0: update cpu_capacity 1024
[    0.056788] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.056826] [bcm2709_smp_prepare_cpus] enter
[    0.056981] Setting up static identity map for 0x8240 - 0x8274
[    0.059365] [bcm2709_boot_secondary] cpu:1 started (0) 17
[    0.059800] [bcm2709_secondary_init] enter cpu:1
[    0.059859] CPU1: update cpu_capacity 1024
[    0.059868] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.060433] [bcm2709_boot_secondary] cpu:2 started (0) 17
[    0.060784] [bcm2709_secondary_init] enter cpu:2
[    0.060814] CPU2: update cpu_capacity 1024
[    0.060822] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.061362] [bcm2709_boot_secondary] cpu:3 started (0) 17
[    0.061615] [bcm2709_secondary_init] enter cpu:3
[    0.061643] CPU3: update cpu_capacity 1024
[    0.061651] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.061737] Brought up 4 CPUs
[    0.061849] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.061882] CPU: All CPU(s) started in HYP mode.
[    0.061912] CPU: Virtualization extensions available.
[    0.062848] devtmpfs: initialized
[    0.075939] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.076509] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.077537] pinctrl core: initialized pinctrl subsystem
[    0.078902] NET: Registered protocol family 16
[    0.084724] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.094282] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.094349] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.094581] Serial: AMBA PL011 UART driver
[    0.094953] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    0.596960] console [ttyAMA0] enabled
[    0.601278] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.680607] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[    0.689315] SCSI subsystem initialized
[    0.693294] usbcore: registered new interface driver usbfs
[    0.698926] usbcore: registered new interface driver hub
[    0.704392] usbcore: registered new device driver usb
[    0.719561] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-07-28 12:46
[    0.755270] clocksource: Switched to clocksource arch_sys_counter
[    0.814729] FS-Cache: Loaded
[    0.818088] CacheFiles: Loaded
[    0.837606] NET: Registered protocol family 2
[    0.843237] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.850503] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.857171] TCP: Hash tables configured (established 8192 bind 8192)
[    0.863690] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.869711] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.876443] NET: Registered protocol family 1
[    0.881432] RPC: Registered named UNIX socket transport module.
[    0.887422] RPC: Registered udp transport module.
[    0.892142] RPC: Registered tcp transport module.
[    0.896886] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.904711] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.914566] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.937037] VFS: Disk quotas dquot_6.6.0
[    0.941320] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.950982] FS-Cache: Netfs 'nfs' registered for caching
[    0.957540] NFS: Registering the id_resolver key type
[    0.962692] Key type id_resolver registered
[    0.966927] Key type id_legacy registered
[    0.974155] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.981868] io scheduler noop registered
[    0.985866] io scheduler deadline registered (default)
[    0.991084] io scheduler cfq registered
[    0.998013] BCM2708FB: allocated DMA memory f6c00000
[    1.003034] BCM2708FB: allocated DMA channel 0 @ f3007000
[    1.014374] Console: switching to colour frame buffer device 82x26
[    1.913599] bcm2835-rng 3f104000.rng: hwrng registered
[    1.920560] vc-cma: Videocore CMA driver
[    1.926173] vc-cma: vc_cma_base      = 0x00000000
[    1.932515] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.939510] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.946724] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.978276] brd: module loaded
[    1.993847] loop: module loaded
[    1.999630] vchiq: vchiq_init_state: slot_zero = 0xb6c80000, is_master = 0
[    2.009779] Loading iSCSI transport class v2.0-870.
[    2.017106] usbcore: registered new interface driver smsc95xx
[    2.024456] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.232163] Core Release: 2.80a
[    2.236792] Setting default values for core params
[    2.243065] Finished setting default values for core params
[    2.450591] Using Buffer DMA mode
[    2.455410] Periodic Transfer Interrupt Enhancement - disabled
[    2.462764] Multiprocessor Interrupt Enhancement - disabled
[    2.469907] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.475822] Dedicated Tx FIFOs mode
[    2.481244] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xb6c14000 dma = 0xf6c14000 len=9024
[    2.494273] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    2.524610] dwc_otg: Microframe scheduler enabled
[    2.524688] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8044efec
[    2.532255] WARN::hcd_init_fiq:414: FIQ ASM at 0x8044f35c length 36
[    2.540124] WARN::hcd_init_fiq:439: MPHI regs_base at 0xb787e000
[    2.547754] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.554303] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.563252] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    2.570437] Init: Port Power? op_state=1
[    2.575914] Init: Power Port (0)
[    2.580917] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.589293] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.598087] usb usb1: Product: DWC OTG Controller
[    2.604310] usb usb1: Manufacturer: Linux 4.4.14-v7+ dwc_otg_hcd
[    2.611867] usb usb1: SerialNumber: 3f980000.usb
[    2.619134] hub 1-0:1.0: USB hub found
[    2.624412] hub 1-0:1.0: 1 port detected
[    2.630613] dwc_otg: FIQ enabled
[    2.630627] dwc_otg: NAK holdoff enabled
[    2.630638] dwc_otg: FIQ split-transaction FSM enabled
[    2.630680] Module dwc_common_port init
[    2.631011] usbcore: registered new interface driver usb-storage
[    2.638872] mousedev: PS/2 mouse device common for all mice
[    2.646839] bcm2835-cpufreq: min=600000 max=1000000
[    2.653531] sdhci: Secure Digital Host Controller Interface driver
[    2.661278] sdhci: Copyright(c) Pierre Ossman
[    2.667572] sdhost: log_buf @ b6c13000 (f6c13000)
[    2.745315] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    2.752646] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.760576] ledtrig-cpu: registered to indicate activity on CPUs
[    2.768380] hidraw: raw HID events driver (C) Jiri Kosina
[    2.775586] usbcore: registered new interface driver usbhid
[    2.782709] usbhid: USB HID core driver
[    2.788797] Initializing XFRM netlink socket
[    2.794647] NET: Registered protocol family 17
[    2.800793] Key type dns_resolver registered
[    2.807164] Registering SWP/SWPB emulation handler
[    2.812534] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.814533] mmc0: new high speed SDHC card at address 59b4
[    2.815424] mmcblk0: mmc0:59b4 SD    7.36 GiB
[    2.825195]  mmcblk0: p1 p2
[    2.842189] Indeed it is in host mode hprt0 = 00021501
[    2.846386] registered taskstats version 1
[    2.846693] vc-sm: Videocore shared memory driver
[    2.846706] [vc_sm_connected_init]: start
[    2.847453] [vc_sm_connected_init]: end - returning 0
[    2.847775] of_cfs_init
[    2.847896] of_cfs_init: OK
[    2.895114] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.906274] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.915684] devtmpfs: mounted
[    2.920989] Freeing unused kernel memory: 480K (807f6000 - 8086e000)
[    3.055322] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.063628] Indeed it is in host mode hprt0 = 00001101
[    3.265667] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    3.274158] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.284131] hub 1-1:1.0: USB hub found
[    3.289708] hub 1-1:1.0: 5 ports detected
[    3.392145] random: systemd urandom read with 51 bits of entropy available
[    3.406272] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    3.423574] systemd[1]: Detected architecture 'arm'.
[    3.549138] NET: Registered protocol family 10
[    3.557310] systemd[1]: Inserted module 'ipv6'
[    3.567097] systemd[1]: Set hostname to <raspberrypi>.
[    3.575359] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.686386] uart-pl011 3f201000.uart: no DMA platform data
[    3.695804] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.704470] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.716669] smsc95xx v1.0.4
[    3.781481] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:eb:fb:63
[    4.206384] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.218208] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.229670] systemd[1]: Expecting device dev-ttyAMA0.device...
[    4.239992] systemd[1]: Starting Remote File Systems (Pre).
[    4.249832] systemd[1]: Reached target Remote File Systems (Pre).
[    4.258019] systemd[1]: Starting Encrypted Volumes.
[    4.267221] systemd[1]: Reached target Encrypted Volumes.
[    4.274784] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.290558] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.304193] systemd[1]: Starting Swap.
[    4.312426] systemd[1]: Reached target Swap.
[    4.318773] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    4.329041] systemd[1]: Starting Root Slice.
[    4.337486] systemd[1]: Created slice Root Slice.
[    4.344048] systemd[1]: Starting User and Session Slice.
[    4.353567] systemd[1]: Created slice User and Session Slice.
[    4.361198] systemd[1]: Starting Delayed Shutdown Socket.
[    4.370713] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.378340] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.389153] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.398014] systemd[1]: Starting Journal Socket (/dev/log).
[    4.407656] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.415415] systemd[1]: Starting udev Control Socket.
[    4.424433] systemd[1]: Listening on udev Control Socket.
[    4.431691] systemd[1]: Starting udev Kernel Socket.
[    4.440582] systemd[1]: Listening on udev Kernel Socket.
[    4.447757] systemd[1]: Starting Journal Socket.
[    4.456413] systemd[1]: Listening on Journal Socket.
[    4.463255] systemd[1]: Starting System Slice.
[    4.471750] systemd[1]: Created slice System Slice.
[    4.478504] systemd[1]: Starting File System Check on Root Device...
[    4.516137] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    4.526882] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    4.535230] systemd[1]: Starting system-getty.slice.
[    4.544787] systemd[1]: Created slice system-getty.slice.
[    4.552007] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.562208] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.570491] systemd[1]: Starting Increase datagram queue length...
[    4.584252] systemd[1]: Starting Restore / save the current clock...
[    4.600292] systemd[1]: Mounted Huge Pages File System.
[    4.620382] systemd[1]: Starting Load Kernel Modules...
[    4.633988] systemd[1]: Mounting POSIX Message Queue File System...
[    4.654741] systemd[1]: Started Set Up Additional Binary Formats.
[    4.663942] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.691515] systemd[1]: Mounting Debug File System...
[    4.702945] fuse init (API version 7.23)
[    4.715960] systemd[1]: Starting udev Coldplug all Devices...
[    4.722899] i2c /dev entries driver
[    4.738078] systemd[1]: Starting Slices.
[    4.747561] systemd[1]: Reached target Slices.
[    4.759713] systemd[1]: Mounted Debug File System.
[    4.768676] systemd[1]: Mounted POSIX Message Queue File System.
[    4.780854] systemd[1]: Started Increase datagram queue length.
[    4.808131] systemd[1]: Started Restore / save the current clock.
[    4.821323] systemd[1]: Started Load Kernel Modules.
[    4.832499] systemd[1]: Started File System Check on Root Device.
[    4.846204] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    4.872174] systemd[1]: Time has been changed
[    4.942561] systemd[1]: Started udev Coldplug all Devices.
[    5.091768] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.146622] systemd[1]: Mounting Configuration File System...
[    5.161466] systemd[1]: Starting Apply Kernel Variables...
[    5.176634] systemd[1]: Mounting FUSE Control File System...
[    5.191186] systemd[1]: Starting Syslog Socket.
[    5.201334] systemd[1]: Listening on Syslog Socket.
[    5.208684] systemd[1]: Starting Journal Service...
[    5.219094] systemd[1]: Started Journal Service.
[    5.397796] systemd-udevd[137]: starting version 215
[    5.883410] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    5.898022] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[    5.914289] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    6.090089] snd-rpi-wsp soc:sound: ASoC: CODEC DAI wm5102-aif1 not registered
[    6.142892] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.333707] LDO1: supplied by DC_1V8
[    6.333859] snd-rpi-wsp soc:sound: ASoC: CODEC DAI wm5102-aif1 not registered
[    6.344105] wm8804 1-003b: revision E
[    6.345141] snd-rpi-wsp soc:sound: ASoC: CODEC DAI wm5102-aif1 not registered
[    6.377551] arizona spi0.1: WM5102 revision C
[    6.391055] Adding alias for supply MICVDD,(null) -> MICVDD,spi0.1
[    6.391942] Adding alias for supply MICVDD,(null) -> MICVDD,spi0.1
[    6.391961] Adding alias for supply DBVDD2,(null) -> DBVDD2,spi0.1
[    6.391976] Adding alias for supply DBVDD3,(null) -> DBVDD3,spi0.1
[    6.391989] Adding alias for supply CPVDD,(null) -> CPVDD,spi0.1
[    6.392004] Adding alias for supply SPKVDDL,(null) -> SPKVDDL,spi0.1
[    6.392018] Adding alias for supply SPKVDDR,(null) -> SPKVDDR,spi0.1
[    6.392499] snd-rpi-wsp soc:sound: ASoC: CODEC DAI wm5102-aif1 not registered
[    6.401799] snd-rpi-wsp soc:sound: ASoC: CODEC DAI wm5102-aif1 not registered
[    6.405475] snd-rpi-wsp soc:sound: ASoC: CODEC DAI wm5102-aif1 not registered
[    6.467848] MICVDD: supplied by DC_1V8
[    6.568382] snd-rpi-wsp soc:sound: wm5102-aif1 <-> 3f203000.i2s mapping ok
[    6.988542] systemd-journald[134]: Received request to flush runtime journal from PID 1
[    7.981481] Adding 102396k swap on /var/swap.  Priority:-1 extents:4 across:1781760k SSFS
[    8.021394] cfg80211: World regulatory domain updated:
[    8.021420] cfg80211:  DFS Master region: unset
[    8.021428] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.021441] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.021450] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.021460] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
8.021472 cfg80211(5170000 KHz 5250000 KHz 80000 KHz  160000160000 KHz AUTO(N/A 2000 mBm(N/A
8.021483 cfg80211(5250000 KHz 5330000 KHz 80000 KHz  160000160000 KHz AUTO(N/A 2000 mBm(0 s
8.021492 cfg80211(5490000 KHz 5730000 KHz  160000160000 KHz(N/A 2000 mBm(0 s
[    8.021502] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.021512] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    8.547384] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    8.547577] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.110141] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   10.111147] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   12.097907] random: nonblocking pool is initialized
pi@raspberrypi:~ $ lsmod | paste
Module                  Size  Used by
cfg80211              427855  0
rfkill                 16037  1 cfg80211
snd_soc_wm5102        345572  1
snd_soc_wm_adsp        16851  1 snd_soc_wm5102
snd_soc_arizona        22803  1 snd_soc_wm5102
arizona_micsupp         2718  1
gpio_arizona            2013  0
snd_soc_wm8804_i2c      1536  1
arizona_spi             1558  0
snd_soc_wm8804          8224  1 snd_soc_wm8804_i2c
arizona_ldo1            3156  1
regmap_i2c              3393  1 snd_soc_wm8804_i2c
regmap_spi              1864  1 arizona_spi
snd_soc_rpi_wsp         8100  0
snd_soc_bcm2835_i2s     6354  2
snd_soc_core          126333  7 snd_soc_arizona,snd_soc_wm5102,snd_soc_wm8804,snd_soc_bcm2835_i2s,snd_soc_wm_adsp,snd_soc_rpi_wsp,arizona_micsupp
snd_pcm_dmaengine       3391  1 snd_soc_core
snd_pcm                75698  5 snd_soc_arizona,snd_soc_wm8804,snd_soc_core,snd_soc_rpi_wsp,snd_pcm_dmaengine
snd_timer              19160  1 snd_pcm
snd                    51844  3 snd_soc_core,snd_timer,snd_pcm
spi_bcm2835             6678  0
bcm2835_wdt             3225  0
fixed                   2591  11
i2c_bcm2708             4770  0
bcm2835_gpiomem         3040  0
uio_pdrv_genirq         3164  0
uio                     8000  1 uio_pdrv_genirq
i2c_dev                 5859  0
fuse                   83461  1
ipv6                  347466  39
pi@raspberrypi:~ $ aplay -l | paste
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpiwsp [snd_rpi_wsp], device 0: WM5102 AiFi wm5102-aif1-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
pi@raspberrypi:~ $ sudo nano /boot/config.txt
pi@raspberrypi:~ $ clear
[3;J
[3;J
#hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#sdtv_mode=2
arm_freq=1000
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
#dtparam=audio=on
start_x=1
gpu_mem=128
core_freq=500
sdram_freq=500
over_voltage=2
dtoverlay=i2s-mmap
dtdebug=1
Module                  Size  Used by
cfg80211              427855  0
gpio_arizona            2013  0
arizona_spi             1558  0
arizona_ldo1            3156  1
spi_bcm2835             6678  0
bcm2835_wdt             3225  0
fixed                   2591  11
i2c_bcm2708             4770  0
i2c_dev                 5859  0
fuse                   83461  1
ipv6                  347466  39
  Subdevices: 1/1
  • spambake
    spambake over 10 years ago
    I had a problem with the speakers, too,  so this might be your solution.  Buried in the manual is the warning:
    "It is necessary to supply auxiliary power to the Audio Card in order to drive external loudspeakers. An external power supply with output voltage of 5V, current delivery capability of 2,000mA, a centre positive power plug of internal diameter 2.1mm, and external diameter 5.5mm."
    Using the "AUX power in" jack will also power the Raspberry Pi.  Do not use one of those 12v or 9v supplies that use that same plug - it must be a good solid 5v.
    e14 Contributor over 10 years ago in reply to spambake
    Hi spammbake!
    Your solution had helped me, thank you very much. Anyway, even an output of 5v~1A is extremely enough and it works fine for me.
