Raspberry Pi Forum Can I get DC out of cirrus audio card
  • Subscribers 705 subscribers
  • Views 370 views
  • raspeberry_pi_accessories
Hi , I'm working on a project that requires a low value DC ( adjustable ) to be used as a comparison to a low external voltage. I couldn't see any Blocking Caps on the schematic of the audio card to the "Line out" jack but filling a buffer with constant values using portaudio library in C doesn't give me anything. Is the card capable of DC output? I am using the external scripts that come with the card to set the output to Lineout first and I can play a standard WAV file without any issues.
    update... by using portaudio C library and filling play buffer with a value, it is possible to use the mixer command to set the audio level. This gives a DC output between 0.01 and 1.56v out of the Line out Jack
