Raspberry Pi Forum ADSB using RaspberryPi
  • Subscribers 703 subscribers
  • Views 3004 views
  • dvb_t
  • adsb
  • pizero
mcb1
mcb1 over 10 years ago
I came across this the and thought it might be useful for someone.
https://www.flightradar24.com/raspberry-pi
Required parts
Raspberry Pi*
Power supply for RPI
1 GB MicroSD card  8 GB Memory card to suit
ADS-B usb dongle
Ethernet cable
*Pi24 is compatible with all Raspberry Pi devices, including Raspberry Pi Zero.
Please note that Raspberry Pi Zero has no network port and only one USB port.
Get a USB hub with Ethernet adapter and you are good to go!
As you can see you can even use a PiZero (by adding a USB to Ethernet), so the hardware requirements are pretty low.
This might be ideal for someone who has an older unit around, and is not sure what to use it for.
Cheers
  • clem57
    clem57 over 10 years ago
    If you need help, see Projects using Pi 3 . Although this was setup with Pi 3, It was switched to Pi B+ with same hardware and adition of wireless USB and works just fine. Just note that changing MAC addres will need to re-register again with flightaware.com. Great little project and fun too. Thanks mcb1for pointing this out.
    Clem
    mcb1 over 10 years ago in reply to clem57
    Thanks for that clem57
    It seems that there might be some more script tweaking yet by the developers.
    Unfortunately I can't see where all the 'feeds' are to see if it's worthwhile.
    We are looking at putting ADSB in many of our sites to feed into the system, but any data exported will be delayed.
  • cstanton
    cstanton over 9 years ago
    Have you also seen Raspberry Pi 2 ADS-B Receiver ?
    mcb1 over 9 years ago in reply to cstanton
    No ....  but I wasn't specifically looking.
    I'll stick it into the memory banks and see if I can find some time next year to look at it.
