Raspberry Pi Forum How Can I control Raspberry 3 GPIO Port   from remote  server in a php file
  • Subscribers 707 subscribers
  • Views 1213 views
umitx7
umitx7 over 9 years ago
Hi ;
I am working on a project. I wanna control GPIO ports from  a php file in a remote server.  But the php file can't working properly on raspberry pi 3.
I try call a pyton script in php file.
How can access the gpio ports from remote php file to control local devices;
Example; I am using a server (that server contains the controller php file) , the remote raspberry that  connected monitor will connect the server,  i wanna open or close the monitor)
  • rew
    rew over 9 years ago
    I have made a system where a web page controls three (or four) relays. Those relays were (ehh ARE!) connected to little FETs connected to the GPIOS.
    In my case I just wrote a little php script that did something like
    if (isset ($_POST["out1"])
       system ("gpio write 1 " . $_POST["out1"]);
    Note that like this, this would be a glaring security hole, you need to make sure that the user can only specify "0" or "1" in the place where I have $_POST["out1"] .
  • clem57
    clem57 over 9 years ago
         If you run the Python on the Raspberry Pi 3, check this Setting Up Your Raspberry Pi for Python GPIO Projects . If the server is on the Raspberry Pi 3, then https://www.raspberrypi.org/documentation/remote-access/web-server/apache.md will help you set that up. this way you can use PHP and connect to the web server on the Pi.
    But this will alow direct get/post to the Raspberry Pi https://nayarweb.com/blog/2014/control-raspberry-pis-gpio-with-rest-qt-webiopi/
    Clem
  • umitx7
    umitx7 over 9 years ago in reply to rew
    i tried your code. unfortunately, that's not working.
