Raspberry Pi Forum USB and Ethernet ports suddenly stop working in my Raspberry pi 2
  • Subscribers 707 subscribers
  • Views 1097 views
  • raspberry_pi_space
amine92
amine92 over 9 years ago
As the title says, I recently had a Raspberry Pi 2 Model B. At first, It started working well, with RJ45 cable connected to the Ethernet port and a mouse connected to one of the USB ports. However, after almost a week, the two little lamps in the Ethernet port turned off and the USB ports stop working as they are all broken.
Any help would be highly appreciated !
    balearicdynamics over 9 years ago
    Hello Amine, what kind of test did you tried to be sure that usb is died? And ethernet too?
    Maybe the worth to check from the terminal if hardware is detected by the system.
    Enrico
    mcb1 over 9 years ago
    Can we presume you have pulled the power and rebooted it.
    While it's not the recommended way, if the USB ports aren;t working then the mouse and leyboard will have stopped, and you have no other options.
    BTW. posting the same question twice just confuses everyone.
    ethernet and usb port broken on my raspberry pi 2
  • amine92
    Thank you for your answers guys !
    I just solved the issue. In fact, I've changed the Power supply and everything is working well now !
    Thank you for help image
