Raspberry Pi Forum ethernet and usb port broken on my raspberry pi 2
  • Replies 7 replies
  • Subscribers 710 subscribers
  • Views 3374 views
amine92
amine92 over 9 years ago
As the title says, I've had a Raspberry Pi 2 Model B. At first, It started working well, with RJ45 cable connected to the Ethernet port and a mouse connected to one of the USB ports. However, after almost a week, the two little lamps in the Ethernet port turned off and the USB ports stop working as they are all broken.
Any help would be highly appreciated !
power 5V 2A
16 gb
  • royleith
    royleith over 9 years ago
    It's a bit difficult to investigate without a working mouse and keyboard.
    If it boots to the desktop then it sounds as though the software drivers are not loaded. If you have a multimeter, make sure the 5V pin on the GPIO has 5V on it. If it does, use another computer to reflash the SD card with the latest Raspbian.
    https://www.raspberrypi.org/downloads/raspbian/
  • clem57
    clem57 over 9 years ago
    Try R-Pi Troubleshooting - eLinux.org first
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago
    These are all USB peripherals and fed via a thermal resettable fuse
    try powering down the board for a day or two (The resettable fuse can sometimes take a while to heal itself) and see if that helps
    If not then you will need to start probing around  the board to ry figure a few things out, namely if there are power supply issues
    There should be nothing wrong with running the board for extended periods of time under normal loads, I have one running 24x7 for nearly a year now with no adverse issues.
    mcb1 over 9 years ago
    BTW. posting the same question twice just confuses everyone.
  • rew
    rew over 9 years ago
    My guess would be that somehow you managed to blow up the LAN95xx chip (i don't remember the xx, that xx is different between the B and the B+ by the way.). That would in one blow disable both USB and ethernet, as the chip acts both as an USB hub and as the ethernet controller. If your USB fuses would be blown, then it is odd that also ethernet has stopped working. If your main fuse is blown then it is odd that the PI does something at all. (but the fact that you say that USB and ethernet are not working makes me think that you still have HDMI output.... )
    The LAN chip is powered from 3.3V. If your 3.3V powersupply on the board was broken then the SD card wouldn't work either. So if we assume a single thing has failed then I would say everything points at the LNA95xx chip.
  • amine92
    Thank you for your answers guys !
    I just solved the issue. In fact, I've changed the Power supply and everything is working well now !
    Thank you for help image
  • gadget.iom
    gadget.iom over 9 years ago in reply to amine92
    Good to hear you're all sorted. And thanks for getting back with a result. image
