Raspberry Pi Forum RPi and tshark (-T fields?)
  • Subscribers 705 subscribers
  • Views 1276 views
  • tshark
  • raspberry pi
tonnyvivas
tonnyvivas over 9 years ago
Hello, I'm new with tshark and I'm trying to use tshark to see MAC addresses and their rssi or tx power, but can't seem to find the proper field name:
the command I'm using is:
sudo tshark -S -l -i wlan1 -Y 'wlan.fc.type_subtype eq 4' -T fields -E header=y -e frame.time -e wlan.sa -e wlan.sa_resolved -e wlan_mgt.ssid
And I get:
frame.time wlan.sa wlan.sa_resolved wlan_mgt.ssid
Jan  3, 2017 12:25:03.048773000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.069641000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.092482000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.155865000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.362698000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.383152000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.426263000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.496762000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
Jan  3, 2017 12:25:03.517186000 EST b8:27:eb:1a:d3:2f Raspberr_1a:d3:2f
I've tried: (with no luck)
chan.chan_tx_pow
wlan.dbm_antsignal
wlan.antenna
wlan.normrssi_antsignal
wlan.rawrssi_antsignal
wlan.signal_strength
wlancap.dbm_antsignal
wlancap.ssi_signal
Could anyone help me out?
  • clem57
    clem57 over 9 years ago
    Have you read the man page? https://www.wireshark.org/docs/man-pages/tshark.html
  • jfst
    jfst over 9 years ago in reply to clem57
    maybe these are helpful:
    https://ask.wireshark.org/questions/18484/viewing-rssi-value-in-wireshark
    https://www.wireshark.org/docs/dfref/p/prism.html
    showing:
    prism.did.rssiRSSISigned integer, 4 bytes1.6.0 to 2.2.3
    shabaz over 9 years ago
    Hi Tonny,
    Are you sure this is supported with your hardware? (i.e. have you seen anywhere that people have done this with your hardware, e.g. Pi 3, or Pi 2 and a WiFi USB dongle, or whatever hardware you're using, or is this
    something new you're trying)?
    (What you're doing is not just RPI and tshark, which will work for IP of course, over WLAN, but you're wanting to look at WLAN control-plane).
    It might or might not be supported with the Pi 3, unfortunately I don't know, and I couldn't find a resource online concerning this with Pi.
    If it doesn't work with the Pi 3's wireless hardware, you could try a third party WiFi USB device. If you're going to do that then you will need to check (perhaps on tshark forums) if it will work for 802.11 control-plane
    snooping with Linux. If this is supported, then it is likely to work on the Pi too.
