Raspberry Pi Forum Pull request to include Cirrus driver in official RPi kernel
  • Subscribers 707 subscribers
  • Views 776 views
  • raspeberry_pi_accessories
hiassoft
hiassoft over 9 years ago
I've submitted a pull request to the RPi kernel to include the reworked Wolfson/Cirrus driver in the official RPi kernels
https://github.com/raspberrypi/linux/pull/1810
It would be great if some of you could compile and test this PR and give some feedback on Github, maybe we can finally have out-of-the-box support for these soundcards after - ahem - about three years image
so long,
Hias
  • abhayap
    abhayap over 9 years ago
    Thanks Hias! I see that it was merged.
  • pyrolator
    pyrolator over 9 years ago in reply to abhayap
    Hi all,
    so you say the Cirrus driver codes are now in the official Raspbian kernel source tree? I suppose there is no readily available image yet - if i want to build a homegrown kernel, following the instructions at https://www.raspberrypi.org/documentation/linux/kernel/building.md , which Git branch would i use to build from? Or any other easy path? Guess its some 15+ years ago since i built my last Linux kernel ;-)
    Cheers
    Andreas
  • hiassoft
    The Cirrus driver is now included in the next firmware tree: https://github.com/Hexxeh/rpi-firmware/commit/ca3422d28e33db6e17016874befdea4ee70358c1
    On Raspbian run the following command to get it:
    sudo BRANCH=next rpi-update
    If you want to compile yourself use the 4.9 kernel tree https://github.com/raspberrypi/linux/tree/rpi-4.9.y
    so long,
    Hias
  • pyrolator
    pyrolator over 9 years ago in reply to hiassoft
    Hi Hias,
    tx a lot, compiling the kernel from the rpi-4.9.y branch (with default settings); and using the guideline from your webpage to activate the C/L card went smoothly! Now playing MP3s using VLC, just great!
    Cheers
    Andreas
