Raspberry Pi Forum Error Playback wav file in python script
  • Subscribers 705 subscribers
  • Views 1422 views
  • raspeberry_pi_accessories
register25
register25 over 9 years ago
Hey all, I am facing a problem playing back wav/audio files in python on my raspberry pi + cirrus logic audio card setup. The file being played back is always buzzing and full of distortion. This problem is only faced when I ran the playback script on python, and the playback is normal using aplay-. Can anyone advice me on this?
Below is the playback python code. Please help me to see if everything is fine. Thanks.
def playAudio():
    import pyaudio
    import wave
    CHUNK = 1024
    wf = wave.open('White_Noise.wav', 'rb')
    p = pyaudio.PyAudio()
    stream = p.open(format=p.get_format_from_width(wf.getsampwidth()),
        channels=wf.getnchannels(),
        rate=wf.getframerate(),
        output=True)
    data = wf.readframes(CHUNK)
    while data != '':
        stream.write(data)
    stream.stop_stream()
    stream.close()
    p.terminate()
  • clem57
    clem57 over 9 years ago
    Instead of blocking mode, try callback mode
    """PyAudio Example: Play a wave file (callback version)."""
    import pyaudio
    import wave
    import time
    import sys
    if len(sys.argv) < 2:
       print("Plays a wave file.\n\nUsage: %s filename.wav" % sys.argv[0])
       sys.exit(-1)
    wf = wave.open(sys.argv[1], 'rb')
    # instantiate PyAudio (1)
    # define callback (2)
    def callback(in_data, frame_count, time_info, status):
       data = wf.readframes(frame_count)
       return (data, pyaudio.paContinue)
    # open stream using callback (3)
       output=True,
       stream_callback=callback)
    # start the stream (4)
    stream.start_stream()
    # wait for stream to finish (5)
    while stream.is_active():
       time.sleep(0.1)
    # stop stream (6)
    stream.close()
    wf.close()
    # close PyAudio (7)
    p.terminate()
