Raspberry Pi Forum Raspberry Pi 2 1GB
  • Subscribers 706 subscribers
  • Views 461 views
Raspberry Pi 2 1GB
does anyone know when installing retropie using an externally powered hd via a USB port what is the biggest size it will accept.
    Hello Charles,
    I think there is not a particular limit as the accepted size depends on the operating system charactirsitcs. I have used a PI 2 with the same configuration as yours with a 500 Gb and 1 Tb hard disk without problems.
    Enrico
  • rew
    rew over 10 years ago
    The 'pi runs Linux. A reasonably recent version of the kernel. So for "bigger" systems it has already been necessary for a while to "fix" the limits that are encountered at 2T(*) and 16Tb(#). So... my guess is that you're good for a few Pb.... (<- more disk than you can afford to buy.... if you sell the house).
    (*) 32 bit block numbers, where the blocks are 512 bytes.
    (#) Something to do with the ext3/ext4 filesystem.
