Raspberry Pi Forum Wolfson Audio Card can't record from linein with darkice and playback on speaker with squeezelite
  • Subscribers 704 subscribers
  • Views 410 views
  • raspeberry_pi_accessories
jfz
jfz over 9 years ago
I'm having an issue with my Wolfson Audio card using this Ragnar's image on my Rpi https://www.element14.com/community/message/106822/l/re-wolfson-modified-noobs-raspbian-zipped-img-cannot-unzip-new-down…
using darkice localy on the Pi using this post https://www.element14.com/community/external-link.jspa?url=http%3A%2F%2Fwww.t3node.com%2Fblog%2Flive-streaming-mp3-audio…
And icecast on my ubuntu server.
Casting work great image thanks to all this people !
By the way I still have an issue wanting using the same Pi to play the stream on the Wolfson speakers.
I have squeezelite on the Pi and the LMS on my ubuntu server. Both communicating well with each other.
when I use on my Pi
mplayer http://myipserver:8000/mylive
while he's streaming, it works great too on the speakers.
Equal when I m using squeezelite with some music on the LMS and without streaming with darkice.
But when I play the stream from squeezelite, only annoying noises are going out the speakers.
The reason I prefer to use squeezelite is to be able to sync the playing stream with my others squeezelite players (Rpi too)
I m using Ragnar's darkice.cfg too image
lauching squeezelite like this :
sudo /usr/bin/squeezelite-armv6hf -o sysdefault:CARD=sndrpiwsp
here are the command someone could ask me to understand what is happening :
aplay -l
**** Liste des Périphériques Matériels PLAYBACK ****
carte 0: sndrpiwsp [snd_rpi_wsp], périphérique 0: WM5102 AiFi wm5102-aif1-0 []
  Sous-périphériques: 1/1
  Sous-périphérique #0: subdevice #0
carte 1: ALSA [bcm2835 ALSA], périphérique 0: bcm2835 ALSA [bcm2835 ALSA]
  Sous-périphériques: 7/8
  Sous-périphérique #1: subdevice #1
  Sous-périphérique #2: subdevice #2
  Sous-périphérique #3: subdevice #3
  Sous-périphérique #4: subdevice #4
  Sous-périphérique #5: subdevice #5
  Sous-périphérique #6: subdevice #6
  Sous-périphérique #7: subdevice #7
arecord -l
**** Liste des Périphériques Matériels CAPTURE ****
I'm using basic scripts :
Playback_to_Speakers.sh
Record_from_lineIn.sh
Notice that launching squeezelite with -o sysdefault:CARD=ALSA works too but sound goes on headset output image
Is anyone have an idea about what is happening ?
