Raspberry Pi Forum Wolfson Audio Card - I2C communication issue
  • Subscribers 705 subscribers
  • Views 715 views
  • i2ccontrol
  • wolfoson
  • audiocard
  • raspeberry_pi_accessories
gbharath
gbharath over 9 years ago
I have got the Wolfson Audio Card from element14 to use with a Linux based hardware.
https://www.element14.com/community/community/raspberry-pi/raspberry-pi-accessories/wolfson_pi
I am trying to use it with a linux based hardware for processing the audio data.
However, I am stuck with initial setup of the WM5102 using the I2C Control Interface.
I have tried performing the register read operation using I2C but there is no response from the WM5102. Have double checked the connections and signals, everything seems to be fine with respect to I2C.
I have also provide the reset control from a GPIO pin. But I am not seeing any change on nIRQ as mentioned in the datasheet. Ideally, the high to low transition should be seen on the nIRQ pin after the DSP boot is done.
Did anyone encounter this issue? Am I missing something?
Are there any pre-conditions to be considered?
Thanks in advance.
Gopi
  • psyj
    psyj over 9 years ago
    HI,
    Not sure you have found the answer elsewhere (We have discussed this in another forum ..)    .  The 5102 on the pi card is not connected to the main "bus", but can be found on the secondary header of the card ..... I simply wired across from the header to the 26 pin connector
    Regards
