Raspberry Pi Forum Raspberry pi school challenge help needed
  • Subscribers 704 subscribers
  • Views 1017 views
  • premier_farnell_technology
nicholas.jennings
nicholas.jennings over 8 years ago
i am a student that has joined a challenge in which we have to make a piece of technology using the raspberry pi zero to help people with complex needs. I am having a huge issue with this as my school does not teach computer science or anything as such. My idea is to have 4 pressure pads in each corner of a cushion that when individually pressed will show a green light and when not pressed/ sat on will show a red light. The idea behind this is that the people that look after those with complex needs will be able to see if the person sat down is in an uncomfortable position or not.
To cut to the chase i do not know what i need to program this how to set this up and then to further code this.
if someone could please help me i would greatly appreciate it.
Thankyou
nicholas jennings
  • beacon_dave
    beacon_dave over 8 years ago
    Perhaps take a look at this MagPi eBook:
    https://www.raspberrypi.org/magpi-issues/Essentials_GPIOZero_v1.pdf
    dougw over 8 years ago
    You should be able to connect an analog input card such as ADC Pi Zero and use some force sensing resistors (FSR) to respond to pressure on the cushion.
  • Robert Peter Oakes
    Robert Peter Oakes over 8 years ago
    For an ADC Card and also a GPS Module Oh, and a 5" cool display, check out one of my recent videos here, I show how easy to use each device using standard applications, it may help you
  • beacon_dave
    You don't indicate a budget but if the above ADC options are out of reach, for a low cost pressure pad proof of concept you could perhaps try the paper plate switch technique as used in Raspberry Pi Foundation projects such as the whoopi cusion:
    https://www.raspberrypi.org/blog/whoopi-cushion/
    It uses two paper plates lined with metal foil which are kept spaced apart with some foam material until pressure is applied.
    The technique is featured in the free Raspberry Pi Foundation Physical Computing course on Futurelearn at:
    Teaching Physical Computing with Raspberry Pi and Python
    Create simple systems that respond to and control the physical world using the Raspberry Pi and Python.
    https://www.futurelearn.com/courses/physical-computing-raspberry-pi-python
    which also covers a number of the topics in the GPIOZero eBook I mentioned previously.
