Raspberry Pi Forum Strange problem: GPIO PWM only working when connected to WiFi
  • Subscribers 705 subscribers
  • Views 1109 views
  • wifi
  • gpio
  • wiringpi
  • pwm
  • raspberry_pi_space
  • raspberry pi 3
baweg
baweg over 8 years ago
I've got a strange problem.
I wrote a python script to send an PWM signal to GPIO1 of my Raspberry Pi 3 using the wiringpi library.
While writing the script, the Pi was connected to WiFi so that I could do it all via ssh from my notebook.
I connected a LED and it was changing the brightness as expected.
I put the python script to autostart, disconnected from WiFi and rebooted.
After that the LED did not flash anymore.
I connected to my WiFi again, started the script again an the LED was flashing.
I tried it many times and it never works without connecting to a WiFi before starting the script.
When it worked, I can disconnect from WiFi and it keeps working without WiFi until I reboot the Pi.
Does anyone here have an idea what really is the problem here?
What does a WiFi connection have to do with the GPIO pins?
Bastian
    genebren over 8 years ago
    Bastian,
    I am no expert on Raspberry PI stuff, but it feels like the PI is not completing the boot-up process (without the WiFi attached) to the point where your python script is invoked.
    Good luck on finding a solution.
    Gene
  • baweg
    baweg over 8 years ago in reply to genebren
    I can see from the terminal messages, that my python script starts.
    It also does not print out any errors.
    It executes all GPIO commands, but it has no effect on that pins.
    Then I kill this process via ssh, start my WiFI hotspot, I see that the Raspberry Pi connects to it, start my python script again and it works.
    genebren over 8 years ago in reply to baweg
    Batian,
    Generally speaking, GPIO pins have several registers that control their function.  It is possible that the WIFI code is setting some of these registers, like setting the GPIO pins as outputs.  When the WIFI is absent, the GPIO pins might not be getting set correctly.
    This site has a pretty good discussion of controlling the GPIO:
    https://sites.google.com/site/semilleroadt/raspberry-pi-tutorials/gpio
    Good luck,
    Gene
