Raspberry Pi Forum Raspberry pi 2+ and Adeept RFID learning kit.
  • Subscribers 706 subscribers
  • Views 1257 views
art54
art54 over 8 years ago
First of all i would like to say i am new to this forum and hello to fellow members, my problem is i have bought a pi+ for my grandson with the adeept learning kit, when we looked at the instructions that came with the kit it gives you a Python source code to download being the following,
$ git clone https://github.com/adeept/Adeept_RFID_Learning_Kit_Python_Code_for_RPi.git but when tried to entered into the pi we got a message(cannot remember what it was ) and would not download. Has anyone had this problem if so does anyone no what the correct line should be,
from a computer litterate grandad
THANKS.
    shabaz over 8 years ago
    Hi Arthur,
    It is hard to know without seeing the error message, but perhaps it could be one of these three things:
    1. The '$' sign is not part of the command, so when entering the command, ensure to begin with the git clone part, not $ git clone
    2. An error elsewhere in the line was typed; I'm guessing it was typed by hand, so there is a chance the command was not typed precisely. If this is the case, you can press the up-arrow on the keyboard to recall the line, and then edit it; easier than re-typing the entire line again
    3. No Internet connection, or some other network issue; this can be tested by typing (say) ping bbc.co.uk and seeing if you get a reply (press Ctrl-C to stop that).
    If the issue still occurs, the error message is needed (or at least the first line or two, if the output is long, or take a photo of the output and attach it to the message).
    • Vote Up +5 Vote Down
  • beacon_dave
    beacon_dave over 8 years ago
    You will need to provide the exact error message.
    At a guess, I suspect that your R-Pi wasn't connected to the Internet so cannot reach github.com to download the required files.
    Try opening a web browser on the R-Pi and going here to verify you can access github:
    and where you can download the files manually if necessary.
  • gadget.iom
    gadget.iom over 8 years ago
    In addition to the suggestions above.
    If you are using Raspbian Lite, then git might not be installed.
    This can be solved by installing git:
    sudo apt-get install git
  • art54
    art54 over 8 years ago in reply to beacon_dave
    Hello beacon dave
    The internet was on and running ok, my son in law who is a programmer managed to download it for me before he went back to south Africa, said it was wrong now he's not here i managed to damage the sd card and cannot remember how he did it, thanks for the quick reply. Arthur
  • art54
    art54 over 8 years ago in reply to gadget.iom
    Hi, I am running the main raspian and tried that to no avail, thanx for the quick reply.
  • beacon_dave
    beacon_dave over 8 years ago in reply to art54
    If you have 'damaged' the SD card then you may want to start here:
    https://www.raspberrypi.org/learning/software-guide/
    which will tell you step-by-step how to set up the Raspberry Pi.
