Raspberry Pi Forum Can You Recommend a CO2 sensor for the Raspberry Pi3?
  • Replies 11 replies
  • Subscribers 705 subscribers
  • Views 11011 views
  • scasny
rscasny
rscasny over 8 years ago
I'm assisting a school in a project where the kids want to measure CO2 around their school. They'll use the Pi3. Can anyone recommend a C02 sensor for use with the Pi3?
Thanks.
Randall
    genebren over 8 years ago
    Randall,
    I have no experience with this sensor, but it does seem to be about the least expensive and it should connect easily to an Ri3. (note it measures eCO2 (equivalent calculated carbon-dioxide) concentration within a range of 400 to 8192 parts per million (ppm)
    https://www.adafruit.com/product/3566?gclid=Cj0KCQiAieTUBRCaARIsAHeLDCTXQpDyBEFpBVsdW-xjVaEfLGPx-i06IZl5nreizq-u-znIZjAs…
    Gene
  • rscasny
    rscasny over 8 years ago in reply to genebren
    Thanks Gene
  • michaelwylie
    michaelwylie over 8 years ago
    I've used this sensor:
    https://www.gassensing.co.uk/products/high-speed-sensors/sprintir-co2-sensor/
    It has a digital interface and is easy to use. It's not cheap, but they may be able to get a sample since it's for education.
  • ralphjy
    ralphjy over 8 years ago
    Just as an alternative, I've used this Sparkfun breakout which is essentially the same as the Adafruit part that Gene mentioned https://www.sparkfun.com/products/14193.
    Very simple to use.  Communicates via I2C and can be temperature compensated using an optional thermistor.
    michaelkellett over 8 years ago in reply to ralphjy
    The OP should beware that these (Adafruit and Sparkfun parts) are not really CO2 sensors, being affected by many other things as well.
  • beacon_dave
    beacon_dave over 8 years ago
    Perhaps take a look at the Senseair S8 C02 sensor
    https://senseair.com/products/size-counts/s8-lp/
    which dougw used in his Safe and Sound design challenge ?
    Safe and Sound - Environmental Factors - GAS Sensors - blog 16
  • koudelad
    koudelad over 8 years ago
    Hello, have a look at my similar earlier discussion. CO2 sensor recommendation
    SenseAir, Amphenol and GasSensing offer true CO2 sensors, but they have its price corresponding to the technology used.
  • beacon_dave
    Tom Igoe's 'Making Things Talk' book uses the Hanwei mg-811 CO2 sensor for one of the projects.
    A similar looking one with an interface is listed here:
    https://sandboxelectronics.com/?product=mg-811-co2-gas-sensor-module
    May be of interest.
    dougw over 8 years ago in reply to koudelad
    I've tried both the AenseAir and Amphenol sensors. I like them both, although the Amphenol device I tried was easier to use because it came with an arduino already programmed.
    e14 Contributor over 7 years ago
    I'll start out by saying I work for a company that sells some of the CO2 sensors below. I know this post is 6 months old, but I thought I could add some information not mentioned here.
    CO2 sensors can be broadly broken into 2 camps: non-dispersive infrared (NDIR) and electrochemical (EC). If you breath on them, both will measure a change in CO2, but there are differences.
    NDIR sensors include SenseAir, GSS, Teleaire by Amphenol, Winsen, Figaro (new), and others. They tend to be faster, last longer, and are more accurate. Price $85 and up.  They will last a decade or more. NDIR uses light to measure the wavelength of the CO2 molecule. These are used in almost every commercial-grade CO2 transmitter for HVAC, to measure plant and animal respiration, or any application that depends on fast response (some like the GSS SprintIR make up to 20 readings per second!). Included in this list is the GSS COZIR, which uses an LED lamp instead of infrared to save power. Very cool tech, but it costs a few dollars more.
    EC sensors like the older Figaro line or the mg-811 tend to be smaller, cheaper, slower, and have a shorter shelf life. Price $10 and up. They measure changes in a chemical reaction inside the sensor. The chemicals inside have a shelf life, anywhere from 1-3 years. Also, because these rely on chemistry, they tend to take a few minutes to see a change in CO2 levels. However, because of their low price, they tend to be popular in consumer products and for use by hobbyists.
    If I was going to hook a CO2 sensor up just to show changes in indoor CO2 (for example, good vs. bad IAQ) any EC sensor will work. If I needed more accurate measurements (like changes from 400ppm to 500ppm) and ease of integration I'd look at a COZIR. If I needed complete control, analog or I2C output, high accuracy and proven technology, the SenseAir K30 would be a top contender.
    • Vote Up +5 Vote Down
