Raspberry Pi Forum Im locked out of my Raspberry
  • Subscribers 706 subscribers
  • Views 2564 views
     I just got my raspberry in the mail and now I am locked out I didnt save a password. Is their a way to reboot so the beginning>?
    shabaz over 10 years ago
    Hi Delano,
    If you've got nothing important saved on your memory card then you can just download the freshest software and follow the installation procedure.
    Click on NOOBS here and download it. Follow the instructions there precisely to the letter, and it will work. Don't assume to just drag-and-drop into the
    memory card without following all the instructions because that's not the way it works. All is described at that link.
  • fvan
    fvan over 10 years ago
    Did you change the default password?
    If you didn't, the credentials are most likely the following:
    * username: pi
    * password: raspberry
  • gregoryfenton
    gregoryfenton over 10 years ago
    There is a nondestructive method:
    Step one:
    When you boot your Pi, hold down the Shift key.
    At the Noobs screen, press E
    Click on the tab "cmdline.txt"
    There will be one or (more likely) two lines of text shown.
    At the end of that text (on the same line) add
    init=/bin/sh
    Click OK
    press Esc to boot the Pi.
    Step two:
    The Pi will appear to freeze after a while and the text will stop scrolling.
    Press the Enter key and you should get a prompt
    Step three:
    type in
    passwd pi
    and enter your new password twice when prompted (the default password is raspberry).
    Step 4:
    type in
    sync
    Disconnect the power to the Pi and reboot.
    Do step one again but this time remove init=/bin/sh from the end of the line
    When you're done press Esc to boot the Pi with your new password.
