Raspberry Pi Forum What am I doing wrong?
  • Subscribers 707 subscribers
  • Views 1027 views
  • rasberry_pi_3_b_plus
lhfrew
lhfrew over 8 years ago
Purchased a new Raspberry pi 3 +B, with SD card.  All I get is the splash screen on the monitor.  What can I do? Previous PI 3 works fine.
Larry
  • gam3t3ch
    gam3t3ch over 8 years ago
    Are you using or tried the sd from the other pi?
  • lhfrew
    Yup, both SD's work in "other pi, neither SD's work in the + one...
  • gam3t3ch
    Ok so what I would is make sure you power is  5v 3amp  and then try a new image from https://www.raspberrypi.org/downloads/raspbian/   try that and see if it will work if that dosen't work and you are still unable to boot past that part you could also try  https://berryterminal.com/doku.php/berryboot    since its a pure drop and drag not need to use etcher or any other img software.
    Also make sure no other hardware is plugged in besides hdmi and power for testing.
    If still nothing try another power supply and make sure plugging directly into the wall and not into a power bar.
    Also if you can take a close up of the sd card slot make sure no pins are damaged.
    hopefully something above helps you out a bit or give you something new to try.
    • Vote Up +5 Vote Down
  • fvan
    fvan over 8 years ago
    Sounds like your software is not up-to-date and doesn't have support for the 3B+ yet.
    While the SD card is in a different Pi:
    sudo apt-get update && sudo apt-get dist-upgrade -y
    sudo rpi-update
    That will update the software and firmware. The card should then work in your 3B+.
  • lhfrew
    lhfrew over 8 years ago in reply to fvan
    OK, I'm an idiot... What do I do from the start-up screen before I type
    sudo apt-get update && sudo apt-get dist-upgrade -y sudo rpi-update?
  • jomoenginer
    jomoenginer over 8 years ago in reply to lhfrew
    I would suggest to just reimage the SD with the latest version of Rasbian (if that is what you want to run).  The hardware on the RasPi 3 B+ is different than a standard 3 so the drivers will be different and you could run into other issues down the road.
    You can get the image from:
    However, if the B+ came with a preloaded SD card, then I would ensure you inform the vendor you got the board from that the image on the SD card does not work with the B+.
