Raspberry Pi Forum Solder filled pads
  • Subscribers 705 subscribers
  • Views 911 views
  • 3a+
Solder filled pads
ianbinnie
ianbinnie over 7 years ago
Just received my Pi3A+
The Pads for RUN,  PEN are filled with solder, making it difficult to install headers.
  • Gough Lui
    Gough Lui over 7 years ago
    Well, if you have a soldering iron and some quality desoldering braid or a solder sucker, it shouldn't be more than a minute's work to clear them out. I suspect maybe their solder paste application pattern didn't mask the plated-through-holes properly ... but then again, maybe it's something which is different depending on who manufactured the Pi 3 A+ and which batch it came from.
    - Gough
  • ianbinnie
    ianbinnie over 7 years ago in reply to Gough Lui
    I am sure I could do this - BUT it is a manufacturing fault which should be rectified.
    The lead free solder used on modern boards is more difficult to deal with - maybe I should replace my 40 year old soldering station, but I shouldn't have to.
  • ralphjy
    ralphjy over 7 years ago in reply to ianbinnie
    Hi Ian,
    I just received a Pi 3 A+ from Element14 and have similar issues.  My first problem was that the board was shipped in a padded envelope which offers no protection and the thin RPi box was squashed.  That caused me to do a close inspection and I noticed that someone had done rework on the board and did a very poor job.  There were slivers of solder left on the board and apparently it was not cleaned after rework.  I had the same problem with the pads being filled which isn't a big deal for me, but on real close inspection it looks like it had issues with the PTH soldering at the GPIO connector - like the solder temperature was not correct.  Even if this board were to function I would worry about infant mortality.  I am going to see if Element14 will replace this board.  Very disappointed in the manufacturing quality.
    Ralph
  • ianbinnie
    ianbinnie over 7 years ago in reply to ralphjy
    I just looked at the underside of my board, and there are tiny solder blobs, and the extension header does seem to be reworked.
