Raspberry Pi Forum PIJUICE
  • Subscribers 705 subscribers
  • Views 638 views
  • rasberry_pi_3_b_plus
PIJUICE
alton
alton over 7 years ago
I HAVE VISIION PROBLEMS AND TYPE IN CAPITAL LETTERS.  I APOLOGIZE FOR ANY INCONVENIENCE IN ADVANCE.
AS I READ. IT COMES WITH SMALLER BATTERY BUT SAYS YOU CAN UTILIZE LARGER BATTERY FOR UP TO 24HRS..
CAN U SELL WITH LARGE BATTERY ?
WHAT ARE THE FULL SPECS OF THE LARGER BATTERY?
WHAT ARE THE PIJUICER SPECS IN POWER REGULATING ETC.?
I NEED POSSIBLY MULTIPLE FOR SOLUTION SECURITY CAMERA SET UP.
SOME REMOTE.  ALSO SOLAR CHARGER OPTIONS.
PLEASE ADVISE,
HUMBLE REGARDS,
ALTON D DAVIS JR
  • inghernandez
    inghernandez over 7 years ago
    Have you thinked about the size for this batteries?
    i mean maybe the point is to use your Raspberry not as
    mobile device.
  • Gough Lui
    Gough Lui over 7 years ago
    It is not sold with a larger battery - it can accommodate larger batteries and as noted in the manual, you can connect that with the terminal block provided. You are strictly responsible for any modifications or external battery choices.
    The PiJuice specs are fully provided in the datasheet - http://www.farnell.com/datasheets/2608385.pdf
    You will need to come up with your own solutions if you want it to be solar powered - you will need to determine the amount of actual power draw by your applications and connected peripherals, size your panels and converters and batteries appropriately accounting for weather, shading, dust on panel, temperature derating, etc.
    - Gough
