Raspberry Pi Forum PiFace 2
  • Subscribers 703 subscribers
  • Views 1074 views
  • piface 2
PiFace 2
maxx13
maxx13 over 7 years ago
Can not start emulator. Tried the editor to #blacklist-bcm2708 but the editor comes up with a blank screen. blink.py works okay.
Have looked and tried a lot of things. Emulator says can't detect pifacedigitalio.
  • jomoenginer
    jomoenginer over 7 years ago
    Please post the error message you are seeing when you run the emulator, or show the last part of the output of 'dmesg'.   You can check '/var/log/messages' for any errors that may prevent from seeing the Digital I/O 2 board.
    I'm guessing you have gone through the pages at the following link:
    https://pifacedigitalio.readthedocs.io/
    You may try the Web Control option shown here:
    https://pifacedigitalio.readthedocs.io/simplewebcontrol.html
    Ensure SPI is enabled on your RasPi.
    cat /boot/config.txt |grep spi
    dtparam=spi=on
    If this is not found in your config.txt, use 'raspi-config' to enable it.
    You should see 2 SPI devices configured if enabled.
    ls /dev/*spi*
    /dev/spidev0.0  /dev/spidev0.1
    Check the jumper setting on your Digital I/O 2. Both jumpers should be at the '0' position for address 0.
    How are you viewing the Emulator tool?
    You may have to try another GL driver which can be set from the Advanced area of 'raspi-config'.
  • maxx13
    maxx13 over 7 years ago in reply to jomoenginer
    pifacedigitalio.core.addrNoPiFaceDigitalDetectedError: No PiFace Digital board deteced (hardware_addr=0, bus=0, chip_select=0).
    Ensure SPI Yes this was correct
    2 SPI Yes this was correct
    Checked jumpers
    E: Unable to locate package python3-piface
    digital-emulator command not found
    This is a different computer than the one I run on piface2 it does not have email service working on it.
    Have photos of screen errors but don't know to send them yet.
  • jomoenginer
    jomoenginer over 7 years ago in reply to maxx13
    Ensure you have the piface software installed for python 3
    Unable to locate package python3-pifacedigital-emulator on rpi stretch
    https://github.com/piface/pifacedigitalio/issues/35
    For the Emulator not detecting the PiFace Digital 2, you may have to change the speed of the SPI device.
    https://github.com/piface/pifacedigitalio/issues/36
